Automotive articles — auto acoustics
A clean and pleasant sound in the car is a guarantee of a comfortable trip. To do this, you need to choose the right auto-acoustics, which could provide you with the highest quality sound. First you need to determine the desired result: it can be just high power or clear sound.
Standard and most common option: car radio, amplifier and speakers. The second element is necessary only in the event that the power is not enough to play the melodies through the speakers.
All acoustic systems are divided into the following types:
Coaxial acoustics: devices belong to the budget class. Used mainly for medium frequency reproduction. Has an average sound quality, it is easy to install and how properly it has small dimensions.
Component acoustics: it differs with better sound, it reproduces medium and high frequencies. Such devices allow you to enjoy the sound of live and surround sound.
Enclosure acoustics: such designs are equipped with several speakers. It features easy installation and the ability to select individual settings.
In the question of how to choose autoacoustics, you need to pay special attention to the speakers. First of all, consider its types:
Subwoofer — can have a separate design or complement some models of devices. Among the main features, you can distinguish a loud sound, high-quality reproduction of music at low frequencies.
The midrange system is used only in addition to a subwoofer or tweeter.
Tweeter — used to play high frequencies. The main feature is the need to mount the tweeter in the direction of the driver's ear.
The choice of autoacoustics in many respects should be determined by the level of protection against theft, because such devices are almost the main element of the "hunting" of scammers. Some models provide a removable panel: a budget option, but not the most reliable, because it can be easily purchased separately. The most practical solution is a removable panel: you can take it with you or hide it in a safe place in the salon.
Autoacoustics must have a sufficient power parameter. So, pay attention to the nominal figure — power which can handle the device without damaging sound quality. A highly sensitive model will allow you to use it without an additional amplifier.
