Automotive Articles — power tools
TOP-3 petrol and electric saws. Chain saw rating 2022
news_title
Looking for quality petrol and electric saws? This 2022 chainsaw rating will show the most popular models among motorists. The best gas and electric saws 2022. all…
18.01.2022
TOP-3 lawn mowers. Lawn mower rating 2022
news_title
Looking for a quality lawn mower? This ranking of lawn mowers will show the most popular car alarms. The best lawn mowers 2022. all…
12.01.2022
Gasoline or cordless blower?
news_title
What are the advantages and disadvantages of gasoline and cordless blowers? Which blower to choose - battery or gasoline? Tips for choosing a garden vacuum cleaner all…
20.08.2021
How to choose a cultivator or walk-behind tractor — the main dif
news_title
Cultivator or walk-behind tractor what is the difference and why is it needed? Types of cultivators and motoblocks, their power, type of power supply - from the mains or on a battery? Gasoline or diesel cultivator? The answers to all these questions are in the article. all…
05.07.2021
Snowplows: rules of operation and maintenance
news_title
Snowplows greatly simplifies life in the winter snow. With it you can quickly clean the territory from the snow drifts. But, like any other complex devices and mechanisms, snow tools need maintenance and observance of certain rules of operation. It is important that the equipment worked for a long time without interruption. all…
30.11.2020
Grind: types and their scope
news_title
What are Grind? This issue is quite extensive and multi-faceted, because, in addition to all the known angle grinders (Bulgarians), there are many varieties of these tools. As a rule, they have a highly specialized field of application, so it is important to know to what works are different types of grinding. Let's look at the basic types and scope of modern grinders. all…
19.09.2020
How to choose the snow thrower?
news_title
How to choose the snow thrower? How to choose the right snow removal equipment for home and professional use, on any design features to look and what is important to know in advance about this technique before buying. What features should have a good snow blower. In this article we will tell you more about modern technology especially for snow removal. all…
03.09.2020
How to choose a blower?
news_title
How to choose a blower? How to choose a garden vacuum cleaner for home and professional use, what features to look and what to consider before buying. What features should have a good garden blower. All these questions you know the answer, if you read this article. all…
29.08.2020
How to choose a punch?
news_title
How to choose a punch? How to choose a tool for home and professional use, what parameters to look and be sure to take into consideration. What should be a good puncher, able to cope with any challenge? On this and not only to read this article. all…
27.08.2020
How to choose electric planer?
news_title
How to choose electric planer? Electric Planer allows rapid processing of wooden pieces of furniture, building structures, etc. From the right choice in this case depends very much, including the quality of the result. In this article we consider the features of different types of electric planers, as well as additional features that are worth watching before you buy. all…
25.08.2020
How to choose a grinder?
news_title
How to choose a grinder? This is an important question that is often asked by men who are to work with metal or concrete walls. This tool allows you to perform several important functions: cut, polish, polish. Let us consider the features of grinding machines and their main technical parameters that will help to buy a reliable and high-quality tool. all…
20.08.2020
How to choose a garden pump?
news_title
Garden pump is used for watering the garden and the water supply to the area, including for domestic use. When selecting the pump is important to consider all the features of: type of design, purpose and technical characteristics and power performance. After reading this article, you will learn how to choose a garden pump to make it work effectively and for a long time. all…
18.08.2020
How to choose an electric jigsaw?
news_title
To work with the tree at the time of repair often require electric jigsaw. This tool allows the saw to cut material therefrom and elements of various shapes. If you want to buy a jigsaw, make sure in advance should know the main technical parameters of the instrument, it is important, as this will depend on the effectiveness of its work. In this article we will discuss what are the jig, and that it is important to consider before buying. all…
15.08.2020
How to choose brushcutters?
news_title
Motor brushcutters need to care for the garden and the local area. It is a compact handheld instrument that allows you to easily remove excess grass or procure hay for animals. Choosing brushcutters important to take into account many parameters that affect the usability and performance of the tool. In this article we will talk about the types and characteristics of gasoline grass braid. all…
13.08.2020
How to choose a drill?
news_title
Drill an indispensable tool if you need to drill a hole in the wall. For example, without it can not hang a picture or shelf. Therefore, every man at home must be a drill. By choosing this instrument must be approached very carefully, because now manufacturers are offering a lot of different models. In this article, you look at the types and characteristics of instruments and options that are worth watching, if you're going to buy a drill. all…
11.08.2020
How to choose a screwdriver?
news_title
Screwdriver a necessary tool for any man. With it you can easily assemble furniture, produce various household repairs and more. If you do not know how to choose a screwdriver, then read our article. Our experts will tell you in detail about the different types of features of the device and the fact that we should look at before buying a screwdriver. all…
08.08.2020
How to choose a circular saw?
news_title
If it is necessary to saw a straight sheet chipboard or plywood, then no circular saw can not do. This tool is used by masters in the repair and construction, simplifies and speeds up the work. How to choose a circular saw to make it work for a long time and without interruption? This is what we discuss in this article. all…
06.08.2020
How to choose a chain saw?
news_title
Chain saw an indispensable tool for a country house or master, who often have to deal with the processing of wood. The use of such saws considerably enhances performance, it is convenient and practical. If you want to buy a chainsaw, then we will help you to deal with how to choose the right tool. all…
04.08.2020
How to choose a lawn mower?
news_title
When selecting zagonokosilki very important to determine in advance the kind and working paramterami. Depending on the tasks may be required rachni model. To facilitate your selection process, we polgotovili article that describes the characteristics of different types of lawn mowers. all…
31.07.2020
