Wiper blades - automotive articles and reviews
Each driver encountered a situation where, during the rain, snow, spray falls on the windshield and prevents you from moving safely. In such situations, the choice of janitors in cars is not a matter of comfort, but rather, prevention of emergencies: and who can continue the trip without a road survey? But also about convenience to forget it is not necessary, after all the design should completely cope with the problems.
So, first of all, in the question of how to choose janitors in the car, you need to decide on the type of devices:
Frame - a classic type, which can be found in most domestic cars. There are metal structures and steel. The latter are characterized by a lower cost, a long service life, increased resistance to frost and corrosion.
Frameless - in their design resemble spoilers. Their main feature is the high resistance to frost. The quality of work depends only on the working tape, because the device does not assume the presence of hinges, bushes and axles.
Hybrid - combined the advantages of the first and second option.
The choice of wiper blades is largely determined by their length. In the manual of the car for each model provide for individual parameters. You can experiment by choosing a device that will be able to cope as much as possible with its task. The only thing - they do not have to cling to each other while working.
In the question of how to choose windshield wipers, pay attention to the following:
Rubber cloth should not have burrs and scuffs - only a smooth surface. The edges must be sharp, without rounded corners.
During operation, the elements move easily, but without play.
Cilia are in most cases equipped with an anti-friction graphite layer, but it is recommended that a composite rubber band is present.
The type of fasteners is now generally not important, because the models are equipped with adapters, which implies the use of the design for any car. In the minus temperature, pay more attention to the windshield liquid. There are special models with a sealed enclosure with an internal heating element - ideal if you live in a country with a harsh climate.
