TOP-5 car DVRs. DVR rating 2021!
Every motorist tries to purchase a DVR, since it is he who will provide an iron alibi during an accident, and will also become evidence in court or in other controversial situations. What is a car DVR? This is a special device with which a video camera records everything that happens while driving.
The video quality depends on the resolution of the device's camera. The bigger it is, the better. The most popular models shoot in FullHD, budget models-in HD and below. There are also premium recorders on the market that shoot in SuperHD or UltraHD resolution. For smooth and clear playback of recorded video, it is advisable to choose models with a recording rate of at least 30 frames per second.
When choosing, you should pay attention to the presence of a built-in display. Since you can use it to view footage and manage settings.
The built-in rechargeable battery allows you to record outside the car or without connecting to the on-board network, in addition, it is possible to save video in case of a sudden power failure.
It is also necessary to take into account additional functions, such as: automatic recording on/off, loop recording, camera angle of view, GPS navigation, WiFi module, parking mode, G-sensor, the ability to connect an additional camera.
Every motorist faces a daunting task. Which DVR is the best? Let's try to figure it out. We bring to your attention the TOP 5 DVRs that are most popular. This rating consists of:
- Gazer F730
- Kenwood DRV-A601W
- Xiaomi 70Mai Smart Dash Cam 1S (MidriveD06)
- Aspiring AT260
- Pioneer VREC-100CH
Gazer F730
Gazer F730 will be the first on the list. Its main feature is the ability to diagnose the vehicle. For this, an additional switching unit is connected to the car via the OBD slot. Also, a GPS antenna is built into this unit. Thus, the driver will be informed about all faults. The diagnostic function is launched via Gazer Dashcam IoV application. The same application allows you to manage all the settings of the registrar.
The recorder does not have a built-in screen, so you can control all the parameters from your phone by connecting wirelessly via Wi-Fi.
The high-quality six-layer lens with Sony sensor captures crisp video at 1920 x 1080 resolution. WDR is used to improve image quality. The maximum wide viewing angle of 170 degrees allows you to fully cover your own and neighboring traffic lanes. The device can also rotate 360 degrees if necessary.
Additional external cameras can be connected to the recorder. When choosing, you should pay attention to compatibility with this model. Important functions of this device are the presence of a built-in shock and motion sensor. By connecting the ACG-OBD adapter in the device, you can activate the security or parking mode. In this mode, the recorder performs interval shooting with the engine off and full-fledged shooting when the G-sensor is triggered.
A wireless control button is provided for emergency recording. With this recording, videos are saved in a separate non-erasable folder on the memory card.
This recorder supports the largest memory cards up to 256GB.
Package Contents:
- Car DVR
- Mounting on double-sided 3M tape
- Power adapter
- Wireless control button
- Warranty
- Instructions
Kenwood DRV-A601W
The second on the list is Kenwood DRV-A601W-a video recorder with GPS, HDR, Wi-Fi, CPL filter, magnetic mount and display equipped with a huge set of useful functions. The driver will be able to not only shoot videos of the highest quality on the 8.3 megapixel camera with 4K resolution, but also view them on the color touch screen.
Thanks to the 8.3 megapixel CMOS sensor, video recording is carried out at a resolution of 4k and a speed of 30 fps. The result will be high image quality with more detail in the picture. High-quality shooting will be carried out despite the lighting and the speed of movement-the image will be clear and accurate.
The patented magnetic mount, unlike traditional brackets, which use a snap-on mechanism, allows you to easily and instantly install and remove the device.
Using the Wireless Smartphone Link app allows you to change dashcam settings and view footage on your smartphone. You can carry out different actions with videos-post on social networks, cut out the necessary fragments to show to friends.
Package Contents:
- DVR.
- Car cigarette lighter charger (12 ~ 24 V, 4 m).
- 110 cm USB cable.
- Velcro/suction cup car bracket.
- Polarizing filter.
- 64 GB micro-SD SD card.
- Operating Instructions.
In third place in the rating-Xiaomi 70Mai Smart Dash Cam 1S (MidriveD06) is a multifunctional recorder that will ensure safety and comfort while driving.
The device supports the voice control function, and the light indicator informs about operation: green indicates normal operation, blue indicates video recording, red indicates system failure.
Thanks to the high-sensitivity Sony IMX 30 sensor and 7-layer coated glass spherical lenses, the dash cam captures high-quality FullHD (1920 x 1080) videos at a 130-degree viewing angle.
The presence of a special G-sensor, which is triggered on impact, allows you to ensure the safety of video files in a collision in the event of an accident.
A device with a stylish design will harmoniously fit into the interior of any car.
By installing a special mobile application on your smartphone, you can synchronize the DVR with your phone via Wi-Fi. In this case, the user gets access to viewing videos, can download them to the phone, and also manage the settings of the DVR.
Package Contents:
- DVR
- Static sticker
- Car charger
- Micro-USB cable (3.5 m)
- Instructions
Aspiring AT260
The next in the TOP is the Aspiring AT260 video recorder, which is equipped with many additional systems: GPS, Wi-Fi, WDR and others. Their presence makes the operation of the device as convenient as possible for the driver. One of the features of this model of the recorder is a unique swivel magnet-neodymium mount with built-in power, thanks to which you can mount the device on the windshield with just one touch, no additional wires are required. Additionally, a built-in 200 mAh battery is provided.
The device is equipped with high-quality optics that provide excellent picture quality, the maximum available UHD format (2880x2160 pixels). This car DVR has a wide-angle lens that can capture up to five lanes.
The camera, thanks to the built-in WDR function, guarantees a clear picture in any light, it optimizes brightness, protecting it from light, even when direct sunlight hits the lens or when going out into the dark.
Package Contents:
- DVR
- Charger
- Magnetic suction mount on the windshield with a power connector to the mount
- Instructions
Pioneer VREC-100CH
And closes our TOP video recorder Pioneer VREC-100CH. Compact car DVR with a wide viewing angle of 125 degrees and the ability to record video in SuperHD quality with a resolution of 2304x1296 pixels at 30 frames per second. High-end optics and a very light-sensitive matrix, combined with modern Wide Dynamic Range video processing technology-WDR-guarantee excellent visibility and high image clarity, even in low light conditions at night. Also, the recorder has a photo shooting mode with a variable quality level and exposure compensation. A slot for microSD cards up to 128 GB is provided for recording and storing video in high resolution.
Its small size and suction mount allows you to place the recorder on the windshield, and it will not obstruct your view or interfere with driving.
The 2.7-inch screen allows you to conveniently view videos and configure the device. For displaying images on a large screen, the design provides an AV-out.
Package Contents:
- DVR
- Charger
- Instructions
Related materials:
Video recorders: Best Sellers
