Portable booster to start an automobile engine a true helper of every motorist
Many drivers familiar device such as a booster. This compact device is able to help out in difficult situations, when the engine refuses to wind up.
Car Booster a special device, which is designed to help the shrunken the battery to start the vehicle's engine if the battery charge is not enough to perform this feature
The booster may be needed to start the engine:
- cars, which for a long time to stand on the street at temperatures below zero air; with an extremely weak battery;
- in the presence of a leak in the circuit of the vehicle wiring harness.
Design Features portable launchers
Booster (Jump Starter)-it is always a small start-compact charger for the battery. The main feature of these devices is that they also have their own built-in lithium-ion or other large capacity battery pack.
As for the design of components, there is:
- the control unit;
- protection system against overload, overheating and short circuits;
- mode indicator;
- "crocodiles" terminals;
- connector for crocodiles;
- USB connectors for charging external devices;
- panel with buttons for controlling the operation of the device and switch modes;
- some models can also be built-in flashlight.
Basic operating conditions of
Most jump starters for cars has 2 operating modes:
Starting the engine-"Start engine"
This mode is activated if battery still "alive." That is, the battery of the village, but when you turn the key in the ignition switch and try to start the engine will be heard at least a small click of the retractor relay. Naturally it is not recommended bringing the battery to such a state. But if it happened, the booster can help to start the car.
It is also worth mentioning that sometimes the engine does not start due to an error in the system, filled with candles, a clogged fuel filter, and other causes. In these situations, none of the trigger does not guarantee success, you first need to remove the critical failure.
Precharges will be effective, if the battery has lost its charge for a long stay at a negative temperature, due to power leakage in the on-board network, etc.
Please note that when operating in this mode, the device has an active protection that protects it from short-circuiting due to incorrect connection of terminals, reverse polarity. Always when connecting the crocodiles make sure that the red wire-is a plus, and the black-minus.
"Override"
This mode is activated if the battery is completely "dead." Here means the battery condition in which she had almost no reaction to try turning the ignition key.
The feature of this mode is that there is completely switched off the protective functions of the device, so it is very important to follow the correct polarity to avoid short circuit.
Connection Precharges the parallel terminals of the battery under the hood of a car. Sometimes it is possible to connect directly to the terminal of the booster starter, which connects the positive battery cable. This can provide additional power that will contribute to a quick engine start.
Please note drivers in this mode is not recommended twisting a starter for a long time. Capacity built-in battery jump starter is simply not enough for it. A pair to run correctly it should be sufficient. Especially if the engine is in the car usually runs pretty easily.
Choosing a booster for the launch vehicle: on what settings should watch
As with any other charger or Precharges for battery, booster has certain technical parameters that determine the efficiency of its use. Among the main features worth noting are:
Internal battery capacity
From this figure depends on the "Start" the start and duration of the effectiveness of work in the mode of the device.
If the booster capacity will be 5000 mAh, then the supply of the starting current of 200 amperes it will last about 90 seconds. And it is with a fully charged internal battery.
The practice shows that the actual booster can provide up to 3 attempts to start the motor for 15 seconds each. To increase this figure, get their hands on more time is possible only by increasing the capacity of the built-in battery booster.
Terminals
Crocodiles-a very important element. They must be reliable and provide a firm retention of the terminals. Considered the most optimal massive contacts, which are made of copper or brass. they must also have a wide contact surface.
As for the wire, on which it will provide current, then it should also be fairly thick with a good cross-section. This is important, since the start-up usually have to work with a large amount of current and wire should easily handle the load without spark and not melted.
Options
The most common booster is not just a portable Precharges, many models have a lot of additional very useful features that greatly expand the scope of their application. Among them are these:
- built-in flashlight signal;
- the presence of connectors for connecting and charging of smartphones, tablets, laptops and other modern gadgets;
- The integrated protection system;
- the presence of special adapters for connecting to connectors of various types;
- Additional modes;
- durable carrying case for easy carrying and storage, etc.
As you can see, the benefits of the presence of the driver in the arsenal of the devices is obvious. A lot of places do not take, it is always at hand, and the engine can start and recharge the phone on the road. Convenient and efficient device. We hope that our article will help you understand the features of the portable device and the trigger is no longer a question: "How to choose a booster"
In our online store 130.com.ua you can buy booster for starting a car engine in Kiev, Kharkov and Odessa, at a bargain price. Delivery is carried out throughout Ukraine.
Related materials
Starter-chargers: Best Sellers
