Starting and starting-up charger for a car
Technical progress with lightning speed is moving forward. Today it has reached the moment when the start of the car engine is fully automated. Everyone is familiar with the situation when you turn the key in the ignition and the reaction is zero. And no one is immune from this. Including those who just yesterday took a car from the salon. There can be a lot of reasons, and the most common is low battery power.
You can solve the problem yourself. Using the starting or starting-charging device. Their task is to start the engine and charge the battery. If you choose the right model for yourself, you can forget what a discharged battery is due to frost, headlights, radio, etc.
Launchers: what is it
Such designs can only start the engine, which is not enough battery power. The device is connected directly, without the participation of the battery. Due to the “external” current, the necessary spark appears, which is enough to start the engine.
Start-Charger: What's Different
Such devices can both start the engine and recharge the battery. Models are more functional than starters. There are two types: with fast charging, which lasts up to 4 hours, and with the standard-about 14 hours, depending on the degree of battery discharge.
Which is better: inverter or transformer model?
According to the type of construction starting-charging devices are inverter and transformer. The first difference is in the presence of a software card that is different in capacity and mobility. Secondly, it is based on a transformer.
To say unequivocally that it is better is impossible, because everything depends on many other factors. For example, inverter models carry out a pulse charge, they are light and compact, suitable for all types of batteries. But transformer devices have limited functionality-only for 12 V acid batteries.
Which is better: stationary or stand-alone rom?
Stationary models have movement restrictions and are tied to only one point where the source of electricity is located. One of the advantages of such devices-they fully cope with their tasks, compact.
Standalone devices work with their own battery. Their main advantage is the ability to use the charger in “field” conditions. But here you need to regularly check the charge, because it also requires periodic recharging.
What is the difference between a trigger and a ROM?
For a motorist, the difference is that the ROM can both run and charge. The models themselves may differ in functionality, dimensions, cost. Before buying, consider the type of battery, the desired starting current, the presence of additional capabilities of the device, etc. With the delivery in Ukraine, the starting device can be bought in Kiev, Kharkov, Odessa at 130.com.ua.
Materials on the topic
Starter-chargers: Best Sellers
