Overview DVR Playme KVANT
Playme KVANT this is one of the novelties of 2020, a small recorder with a convenient magnetic mount, which is placed on the windshield. The model shows good image quality, and also received an impressive performance. This is a modern multi-function combo device, which also has a function of preventing the driver of the stationary cameras and radars on the road. That is, it combines the capabilities of road recorder and radar detector.
In this article we take a closer look at all the features and capabilities of the video fixation device.
The original design and clever design
The DVR Playme KVANT compact enough housing is made of durable black plastic. The shape of this model is a bit like the previously released UNI registrar.
Mounted device on the windshield, for this there is a reliable arm with a magnetic mount. Sam brackets on glass fixed with 3M-adhesive tape, it is very convenient and reliable than the sucker. Scotch will not give the registrar fall due to shaking and vibration, when often it is necessary to drive on rough roads. The mount has a special, very convenient swivel mechanism, thanks to this, the driver can choose the optimum angle and secure this position using the knurled screw
It is also worth noting that the bracket is an integrated GPS-antenna, such an option to provide a good signal reception. Since connector mains lead is on the upper side attachment, the driver can easily implement the flush-mounted variant. That is, the power cord can be as much as possible to hide in the cabin, so it was not visible, and that nothing prevented.
Furthermore, the recorder has a small display, diagonal is 1.5 inches. It motorist at any time can not only view the captured video, but also to get information (warnings) when approaching his car to areas where fixed mounted cameras and radar speed fixation.
To manage the housing, there are special keys, which are located on the sides of the device. For user convenience, all the buttons have a special marking, which helps you quickly navigate to the appointment of each individual button.
Basic Specifications and features
- High quality image. This recorder is set effective matrix GC2053 and efficient processor Mstar 8336. With this achieved superb quality and clarity of the video. Relieves recorder at 30 frames per second with a resolution of Full HD 1920x1080 pixels. The video is easily discernible in almost any lighting all the important details: marking, road signs, the numbers of passing cars, etc.
- High-quality optics. Sharpness is also dependent on the kind of optics used in the lens. This model has a modern upscale fast lens. The lenses are made of tempered glass and additionally have a special coating to protect its surface from possible mechanical damage during operation. And because it uses the aperture f/1.8, the registrar provides good images even in low light conditions.
- Large viewing angle. This model has a viewing angle of 140 degrees. This is quite residual to a frame includes all the road stripes and even part of the shoulder. You can not worry that something will be lost, all the important details will be recorded, and then it can be used in the event of dispute resolution in case of accident.
- The presence sensor G-Sensor. With a built-in accelerometer, the recorder continuously records the change in vehicle speed of movement: acceleration, harsh braking, turns, etc. Due to this, at the time of the accident, when hitting or any extreme maneuvers the device activates a special procedure for recording when video clips are placed in a protected area of memory. That is, there is no fear that important recordings will be lost.
- Function cyclical record. All the videos that car recorder records continuously. That is, new files as soon as the card will be overwritten over the place of old ones. This is a very useful option, as protects the driver from situations where due to lack of space, important videos can not be saved.
- Supports high-capacity storage devices. DVR Playme KVANT supports the latest memory card format microSD, which belong to the class of 10 the recording speed of up to 64 GB.
- Easy management. The device has a simple and convenient system of manual configuration. The user can choose the settings for shooting, image type information reflected on the rollers. Also supports voice notification with the ability to adjust the volume.
- Integrated GPS. This model has a navigation function, which allows to fix the position displacement of the car, to monitor the speed and route. And all the data: date and time, the rate applied to the video. This is an additional advantage in the analysis of situations on the road. If necessary, the car owner can view all the data on the movement of the machine, using the service Google Maps. Establishing a GPS module, also serves as a radar as displays information according loaded into it a database of fixed cameras and radars. Database updates can be downloaded from the official website of the manufacturer. Very easy to use functionality in a big city, as it allows the driver to avoid a lot of problems, the registrar can replace a radar detector. Moreover, the user can adjust and customize the widget based on their wishes, for example, set the maximum speed limit and set the output range of alerts. In this case, the device will give an alarm signal if the car speed exceeds a predetermined or a specified distance nearer to the stationary camera or radar.
What is included in the package?
The DVR Playme KVANT comes in a box of cardboard with the traditional design of the manufacturer. The kit comes with the following:
- registrar;
- magnetic mount on the windshield;
- charger which is connected to the car cigarette lighter socket via a dedicated cable;
- warranty card.
Summing up
Playme KVANT it is a modern, well-balanced video recorder with a GPS-informant function. It is compact, high-definition images in Full HD resolution and ease of use. This model has the convenient and reliable magnetic mount is placed on the windshield. If necessary, it can be made flush-mounted in the car.
130.com.ua you can at any time to buy DVR Playme KVANT in our online store at Kiev, Kharkov and Odessa, at a bargain price. The catalog contains a large selection of well and other devices of this brand. Delivery of automobile electronics and accessories is carried out throughout Ukraine.
Related materials:
Video recorders: Best Sellers
