Summer car wipers: features and basic design types
Brushes windscreen (windshield wipers) are responsible for the cleanliness of the windshield. And let many people think that it is a trifle, but it directly affects the safety of the driver. And they need at any time of year, because rainfall all year round, and wipers must be removed from the surface of the glass snow, rain water, dust and other contaminants that interfere with good visibility in the vehicle is moving. In this article we consider the features of the summer wipers and what to look for when choosing them.
seasonal automotive wiper
As well as tires from the wiper blades have their own seasonality, which is determined by the design features of the device and the type of rubber that is used in their manufacture. And do not forget the time to change the wipers as a winter version of summer is not as effective and can even cause harm instead of good glass surface.
Among the main differences summer wipers can be identified such:
- 1. They are made of a hard rubber (in the part of silicone, rubber and graphite), while the winter is often made on the basis of silicone, which in the cold for a long time remain flexible. But in the summer too soft rubber grip reduces the glass surface, the quality of removing dirt greatly decreases.
- 2. They have a special rubber cover that winter provides additional protection from snow and ice. Because of the effect of the sail in the summer, winter wipers at high speed loosely adjacent to the glass, between the brush and the surface being cleaned forms a void.
Summer wipers may also have different designs, all divided into three types: framed, frameless and hybrid
Frame
Drivers often referred to as the summer times the usual frame windshield wipers. Their design is unchanged for decades. is such a brush with a rubber band, which is fixed on a metal frame, consisting of several moving parts in common are called rockers. The main feature of this framework is uniform pressing of the rubber brush to the glass surface. To provide additional rigidity to the rubber band placed small steel plate.
Please note that in this type of the janitors may be a different number of arms 3, 5 or 7. Outwardly it is very easy to determine, since the brush will have a different number of poles, which is held on the rubber brush 4, 6 and 8, respectively, . Here it is worth considering that despite the fact that a greater number of poles facilitates a better fit, it also reduces the reliability of the design. If one of the hinges suddenly fails, it will lead to the formation of the glass strips and divorce.
In spite of its simple construction, these wipers are very popular because they are the cheapest option. These brushes work effectively, the design allows them to be used on any vehicle, any bending of the glass. However, they are not very durable, eventually joints become loose and have to go to the store for new wipers. To prolong their life can change the rubber portion of the brush, but it is still a temporary solution.
The pros and cons of frame car windshield wipers:
✚ Universal and extremely simple design
.✚ A small price
.✘ A small working life
.✘ old-fashioned design
.✘ Not the best aerodynamics
.Frameless
This version already has a completely different type of design. These wipers offline usual metal frame, and the brush clamp rubber to glass is achieved by using a resilient steel plate, inside the brush. That it gives the janitor form.
One of the most important advantages of this type of wiper is a good aerodynamics and uniform clamping of the brush to the glass surface. However, there is a small nuance: the shape of the brush must match the curvature of the glass a particular brand of car. If you choose a model incorrectly, rubber part is loosely fitted, may form stripes, divorce, will be heard creaking under the wipers and other troubles. And this can be eliminated only by the replacement brush to the appropriate shape.
It is also worth mentioning that due to the absence skeleton with moving parts, these summer wipers are more reliable and durable. They can be used in any weather in the summer and in the off season without fear of freezing.
The pros and cons of frameless wiper:
✚ with prolonged use
.✚ Good aerodynamics
.✚ Relative all-season
.✚ The original design
.✘ The need for the selection of a specific car model
.✘ High Price
.hybrid
Structurally, this type is very similar to a conventional carcass wipers-they also have a rocker arm, a rubber band and hinges. But there is a significant difference-the mechanism safely tucked away under a special streamlined plastic casing. With this version of this design has received some benefits.
In particular, improved, joints are protected against ingress of dust and gnaw. This increases their lifetime. Compared with conventional wireframe, they serve much longer.
It is also worth noting the possibility of work in the off-season, this contributes to the casing that protects the protection of a metal frame at a low temperature of freezing ice.
The pros and cons of hybrid wipers:
✚ Good aerodynamics
.✚ Protecting designs of dirt
.✘ The high cost
.What wipers better to choose for the summer?
The answer to this question is quite difficult, as the opinion of many very subjective. Some drivers prefer to change often inexpensive frame classic wipers, while others prefer frameless, choosing excellent aerodynamics.
reliably determine which is better can only be experienced by so you can understand exactly what may best option is right for you and your car.
In our online store you can buy wipers the summer any design at a very attractive price.
Related materials
Wipers: Best Sellers
