Which is better-an action camera or DVR?
Now action cameras, which are often used instead of regular DVRs, are becoming increasingly popular. They are compact and simplicity in use, the installation of an action camera doesn’t take a lot of time, they are easily fixed on a windshield. However, not all the functionality of DVRs have action cameras. Therefore, consider the main features and the advantages of both devices, and we will help determine the answer to the question: “Which is better-an action camera or DVR?”.
Action Camera Features
These devices were previously often used only by lovers of extreme pastime. They are resistant to moisture from-snow or rain, they can be removed under water, on strong wind, while receiving excellent sound and image.
However, despite these advantages, the disadvantages of action cameras are the impossibility of working for more than 2-3 hours without recharging. They are also not adapted to autonomous operation and have a very high cost.
Purpose of DVRs
The main tasks that the registrar performs are recording everything that happens around the car during a trip or on a parking lot. They work directly from automotive electronics, so they turn on and turn off with it.
- DVRs can be of different sizes, and the larger the device, the better the image quality and the sensitivity of the device itself.
- Autoregistrars have a solid mount, shape, and types of which manufacturers of action cameras borrowed precisely in these devices.
- GPS modules and image stabilizers are considered a normal function in action cameras, and here DVRs these options are of secondary importance.
Choosing a device: DVR vs Action Camera
Having dealt with the features and purpose of each device, you can determine which one is better for use when driving time in a car. Although at first it may seem that these are completely different devices with different functionalities, still in some cases, the action camera will perfectly cope with the functions of the DVR. For a more detailed study of these devices, let's compare the main features of each device.
1. Record video. The engine starts — the DVR is set in the action, and after the initial setup, the driver forgets to turn on, because the device is activated and turns off by itself. Regarding the action camera, it must be turned on after the engine is started, the recording is turned off or stopped also in manual mode.
2. Work in offline mode. At the parking lot, the DVR turns on when something happens close to the car, since many models are equipped with motion sensors. Having an action camera in an auto will not be able to protect a car, but on the contrary, it will only attract too much attention.
3. Quality photos and videos. The expensive models of action cameras fix up to 120 frames per second, and their resolution can be 1920x1080. With these options, you can get an accurate and clear image. Some models of DVRs from popular manufacturers may also provide a not-less-quality and clear picture. Although in the case with viewing angle, action cameras have it significantly more than any recorder.
4. Battery. As it is known, recorders operate from electronics, action cameras can function autonomously, but not more than 2-3 hours. At the same time, if the charge sets, the action camera can be connected to the cigarette lighter, which allows you to record continuously.
5. Overheat. Despite the possible uses of action cameras, they all not can fully work at high temperatures. Therefore, leaving it in the auto on heat is the probability of failure of the device. In difference from action cameras, DVRs work well in all weather conditions.
Another important factor is device memory. Action cameras after filling the memory card stop their work. However, there are some modern devices that have the function of cyclic rewriting, due to which old files are replaced with just made videos.
Most DVRs have a cyclic overwrite feature. Many of them are also equipped with the option to protect certain segments of the survey: during time of a sudden change of speed, at abrupt turn or stop.
The best solutions for motorcycle owners
Feel all the benefits of action cameras can motorcyclists, cyclists, other owners of such equipment. They are an excellent option for fixing everything that happens during time on a this transport. The action cameras are excellent and are quickly mounted on the steering wheel, helmet, and transmit an excellent and exact image, despite the weather: rain, snow or wind. In counterbalance with action cameras, DVRs are less suitable for this technique.
Additional functionality and equipment
Many models of DVRs and action cameras have this addition to the functionality:
- Bluetooth;
- WI-FI;
- video stabilization.
Most models of DVRs can also be equipped with GPS navigation and anti-radar. In a set of each type of device includes a fastening element, a USB adapter and, in fact, the device itself.
Which device to choose?
Undoubtedly, the classic video recorder will never be able to compete with an action camera, since it is more suitable for use in an car and for performing its functions. Therefore, in this case, the action cameras are significantly inferior to the registrars. On the other hand, with the help of the autoregistrar, it will never be possible to get a clear and accurate picture of what is happening. In addition, no matter how costly and excellent the recorders were, all the same action camera transmits the image much better. And in some situations this is especially important during accident time, for example, where it is sometimes very necessary to see particularly fine details.
Both options have their strengths and weaknesses, so the choice is up to the driver. If he likes great shooting quality and it’s easy to turn on and off the gadget every time, then the action camera would be the best option. For lovers of the classics, DVRs are perfect, they are, by the same, more affordable and budget option.
Now on the market there are new products in this direction-hybrid devices combining an action camera and a DVR. Therefore, for those who find it difficult to decide, these innovative devices will be suitable.
Without a DVR is difficult on the road, because with it you can always record some event or incident. Therefore, to buy a DVR or an action camera is sometimes very necessary. You can familiarize yourself with the excellent choice of devices of different brands at us on the website. Action camera buy in Kharkiv, Kiev, Odessa with delivery in Ukraine can be on 130.com.ua.
Materials on the topic:
Video recorders: Best Sellers
