Down with delusions-choose car audio correctly!
For many drivers, the first-class sound in the car is of great importance, and the sound quality of a regular audio system does not suit at all. Of course, the search for a new car radio, a choice of speakers, an amplifier, the purchase of speakers or Car subwoofers into the car begins. Information mass, and you need to choose one correct option. The situation is aggravated by a lot of marketing information, which does not quite correctly reflect reality. It is extremely important to be able to separate fair comments from advertising gimmicks, or simply inaccuracies. In order for you to concentrate on the really important parameters, we picked up a number of popular misconceptions that can influence the choice of the best car audio for your car.
Do not confuse rated and maximum power.
When choosing a radio tape recorder , be guided by the figure of nominal, which means real, power. This parameter speaks about performance and really plays an important role in the use of the device. In turn, the maximum power is the index of the peak load that the manufacturer receives when testing the strength and this is the limit after which the equipment fails. There are cases when the indicator is claimed that it has nothing to do with reality at all. The thing is, in fact, the buyer will not check it for authenticity, but the beautiful figure is impressive and seductive. Thus, before you buy a car, pay attention to the rated power.
It is a matter of quality, not quantity.
Let's face it-recently it has become fashionable to install a mountain of speakers in the car. Designers and strive to create an image of a supercar with the installation of two dozen columns around the cabin. Only a large number is not always displayed on a strong sound.
Moreover, there are cases when the equipment with a lot of car speakers is even worse, as the noise and rattle fall from all sides. In fact, quite powerful front car speakers, a subwoofer and an amplifier for 4 channels, the sound atmosphere will fascinate and sound beautiful.
The entire set of the same brand is optional.
Manufacturers provide a complete line of components, but not all elements are equally good. For example, the radio and speakers will be excellent, and the subwoofer-mediocre. A specific device can get the best estimates of experts, but this does not mean that all components are automatically the best of its kind. If the seller does not tell you about this, now you yourself know everything.
Excellent set of components from different brands.:
“About Everything and Nothing”
Do not chase the maximum number of functions. Additional features pretty tempting, but in the end, it may appear on poor quality and weak work of the main task. There is an opinion that it is peculiar to manufacturers to mix many functions, that they manufacture devices for the lower price segment, which helps to increase sales. Reputable manufacturers, in turn, focus on a specific function and bring its quality to the highest possible level.
Dear car-does not mean quality car audio.
It's all very simple-expensive components will decently increase the price of the car, which can be displayed on good sales. Not all consumers will appreciate the high-quality acoustics, and the professionals still try to refine it. Thus, it is not profitable for the manufacturer to invest a lot in a powerful full-time audio system, although such instances exist on the market.
Choosing car audio for a car brand is not the best choice.
There are a number of parts that are bought strictly for the brand and model of the car, but remember that this is absolutely not relevant to acoustics. The fact is that autoacoustics manufacturers often do not produce music, but order from companies specializing in this.
The condenser will not replace the battery.
The task of the capacitor is to accumulate energy and, if necessary, give it away. The point is not to replace the battery, but to give away some of its energy to ensure good sound when the battery does not have enough charge. A capacitor is a power consumer that accumulates energy and then consumes its own leakage, but not battery leakage. It must be emphasized that this device is not required for every speaker in the car, but only for the most powerful, with an actual power of several hundred watts.
It’s not enough to understand electrics in order to properly install car audio speakers.
It is quite commendable to do some repair work yourself, but in the name of economy, you shouldn’t go to extremes, and here's why. Embedding the radio in the dashboard-it's not difficult, but in this case, you need to connect the wiring meters, and most importantly-adjust the sound. It turns out that there are many nuances that give a good sound, and poor-quality installation will not reveal all the possibilities of the equipment. Thus, do not be lazy to find the master of car audio.
Buy cheap car audio, or a miser pays twice.
Obviously, you always want to buy good car audio cheaply , but in this respect, you shouldn’t go too far since your waste may be completely worthless. Solution on the surface-contact the sound specialists and make an optimal conversion plan, then you will not need to redo everything several times.
A good subwoofer will not help with weak standard equipment.
This is a statement. Point. A good subwoofer will work with good hardware, and a bad one will also work poorly. Because you should not hope that one element will put the entire audio system to a new level of sound.
The quality of the music is not determined by the volume.
To date, there are a number of competitions in car audio, which determines the level of sound pressure. In fact, do not overestimate this figure and push it away when choosing car audio in the car. A lot more fun you get from the high-quality sound, when you can hear all the musical touches.
The world of automotive sound is striking in its scale, and, in turn, will not be a mistake at all-look for reviews on car audio on the Internet and study audio ratings. We believe that you will choose the best option and will enjoy the excellent sound of the music. Buy acoustics in cars with delivery in Ukraine can in the online store 130.com.ua
Materials on the topic
