How to choose the right starting device for a car?
The most common problems with a battery occur in the winter, as a severe frost makes the battery faster. Yes, and in principle, the reasons for such problems can be mass: unclosed doors, not turned off lights, anti-theft devices.
One of the best ways to solve a problem on your own is to use a starting-charging device. A regular and timely charging will extend the life of such structures. But all models differ in purpose and functionality.
Chargers
Only designed to charge batteries, but not able to run them. Works from an electric network. Simpler is the usual network explorer from charging to your battery. It can work with batteries of various capacities. Charger models differ in the range of functions: desulphation, restoration of exhausted batteries, automatic operation, winter mode, voltage.
Advantages of such models in their complexity and ability to restore non-working or old batteries. Among the main drawback is the inability to start the engine.
We recommend
Start-Chargers
Such models are more functional, since they work in two modes: start-up and charging. Sometimes the starting-charging devices are equipped with another function-accelerated charging. Additional features may include a timer, protective systems, battery recovery modes.
Pros:
+ Versatility: charges and launches.
+ Availability of several functions and modes.
+ Reliable protection.
Today you can buy models with a built-in battery that work even in the absence of an electrical outlet.
We recommend
Launchers
Only intended for engine start. Differs very fast work: cranks the car starter for a couple of minutes. Their main difference is the ability to supply high current. Often, models of starting devices (or, as they are also called, jump starters) are equipped with a built-in battery. Here you need to ensure that it is not discharged.
Accordingly, the main advantage is mobility. The disadvantage is the presence of the start function only. Therefore, such models are limited in functionality.
We recommend
Household or professional rom?
Of course, for home use, it is better to buy household models. They are characterized by compactness, so the charger can be easily transferred to any convenient place. Well, the price is much lower.
If the design is purchased for workshops, fleets, service stations, then we recommend choosing professional models. They have an increased charging and starting current. Often equipped with additional modes and functions. Designed to work with different batteries, therefore, are universal. The main drawback is too much weight, so for ease of transport, they are equipped with wheels.
What is battery power?
Battery Capacity is a parameter of the current that the battery gives in an hour. It is important to consider when choosing a charger, since such structures indicate the maximum battery capacity. This value indicates how much battery can charge or run the design.
Choose the ROM should be given 1 to 1 and better with a margin.
What is the starting current enough?
Starting current ROM is responsible for starting the engine. If you have a gasoline engine, then you need to choose a model taking into account 1 to 1. For example, the battery capacity is 100 A/h, then the required starting current will be 100 A.
If you have a diesel, then increase the proportion to 1.5. For example, the battery capacity is 100 A/h, then the required starting current will be 150 A.
Please note that there is no need to take a close-up model. For example, if the battery is discharged to zero, and even in conditions of severe frost, then a greater starting current will be needed. Here also consider, for which car you choose a charger. For example, for a truck, parameters are needed twice as much.
On average, take devices with these values:
- 100 A-for passenger cars;
- 150 A-for jeeps and mini-vans;
- 200 A-for small trucks;
- 500 A-for large trucks, tractors, combines.
Battery Voltage
Car batteries come in 6 V, 12 V and 24 V. Standardly choose 12 V. If you have different vehicles, it is better to choose universal models, for example, so that you can switch to 6 and 12.
So, the battery voltage regarding the type of transport:
- 6 V-motorcycles and motorboats;
- 12 V-passenger cars, jeeps and minibuses;
- 24 V-trucks, trucks, agricultural equipment, tractors.
Advanced Options
Battery desulfation
If the battery is not charged for a long time, then acid salts accumulate inside it. Thus, the electrolyte density is almost zero and the capacity, respectively, too. There will not help standard charging: you will charge the water.
In this case, the desulphation mode will help: charging will be done in pulses, which will eventually break up the salt on the plates.
Automatic charging
If this is a standard charge, then you need to be very careful to prevent undercharging or overcharging. Automatic devices simplify work: you can not follow the process at all. Charging will automatically turn off if the battery is fully charged.
Charge Timer
You set the right time to charge. As soon as time expires, the device automatically shuts off. Efficient feature for faster charging.
Continuous charge
Suitable for inverter ROMs. Necessary to ensure that the battery capacity is not reduced. It is very convenient to use for cars that will not be charged in the near future.
Support Function
The inverter board simulates the battery charging process. The function is effective in order to prevent battery self-discharge. Immediately goes protection from sulfation and corrosion.
Protection against incorrect polarity
Prevents possible incorrect terminal connections. If this happens, the fuses may break. At 130.com.ua you can buy a charging device in Kharkov, Odessa, Kiev with delivery Ukraine.
Materials on the topic
Starter-chargers: Best Sellers
