Select the wiper blade in the winter
Winter, despite global warming, still remains quite severe and difficult to predict the time of year. Often Ukrainian motorists during this period are faced with a variety of serious challenges.
The most frustrating is that the negative impact may be subject to virtually any vehicle components and elements. However, drivers have to pay special attention to those parts of it, which directly affect the movement. In particular, it is important to monitor the work often suffer and the state of the wiper blades, which in the winter, as they encounter atmospheric disturbances directly. In this article we will talk about what is best to choose the wipers for the winter, so that they work efficiently and did not break quickly.
Why in the cold wipers do not work well?
This is a very important point, because if you know the reason, negatively affects the work of staff wiper blades, it is possible in advance to try to minimize their effects.
The following can be attributed to the major negative factors:
- Rubber loses its performance at low temperatures. This is due to the fact that the base of the wiper rubber parts made of silicone, which in the cold loses its elasticity. The resulting frozen brushes can not provide the same effective cleaning glass from dirt and water.
- Antifrost. Due to the accumulation of fluid on the working surface is formed at a low temperature ice crust. The reason is that the standard "janitor" there is no ventilation, and moisture very badly allocated. In fact, the liquid, which then freezes accumulates between the brush elements that hinder its work. Note that this character flaw often for janitors frame type. Frameless frosted less.
These two reasons have given impetus to the engineers of manufacturing companies specializing in automotive accessories, began to look for a solution.
So, what properties should have a car windshield wipers, so that they can well and without any problems in the winter? Which model is better to choose for the winter? These are very important questions for every motorist. And to answer them directly is difficult. The fact that the direct and precise separation "janitors" in the summer and winter, such as it happens with the tires, do not have.
In fact, any servants must be "multisezonnym", it is valid for use in the heat and in the cold. In fact, not all of them are equally well tolerated in the winter cold, and experts say that there are some models that do a better job with winter operation.
The basic properties that are important for winter wiper
The corrosion resistance-this option is very important, because in the winter on the wipers acts not only atmospheric moisture and snow, but also a variety of chemicals that utilities very actively treated roadbed. And most of these chemical substances are very aggressive and can adversely affect the durability of the metal parts are not janitors.
resistance to low temperatures -this is important for all rubber elements and brushes main cleaning sheet. This is due to the fact that it is rubber parts in sub-zero air temperatures become very brittle and lose their working properties.
Resistance to ice crust-to resist frosting winter wipers must have an effective self-cleaning and ventilation system that will not allow fluid to accumulate and form a crust of ice
What models of brushes for the winter are more suitable: frameless or framed
All the proposed brush manufacturers can be divided into 2 groups: the frame and frameless. Already in the title it is clear that they differ in the type of construction, that is, some have the frame, and the second is not. Let's take a closer look at the advantages and disadvantages of these two options:
Frame
Their peculiarity is that they have a framework, which can be either metal or plastic. Moreover, thanks to the special design of the special spring-loaded element provides a tight seal rubber working surface of the brush to the windshield of the car over the entire length of the brush. It is also their main advantage, because thanks to this framing based brush clamp always good enough at several points. This ensures good cleaning surface.
However, this configuration also has some disadvantages:
- a complex structure;
- air resistance;
- the possibility of moisture getting into some design details of where it can build up.
That is why winter use these brushes often associated with freeze-up that reduces their effectiveness, as they lose their operational properties.
Frameless
They have no frame, in which case the brush is in the form of a small, relatively thin rod of lightweight plastic, which has a special elastic element. The advantage of this construction-a small thickness and weight, which minimizes the resistance to opposing air flows, and also provides good heat liquid
.Among the shortcomings can be identified weak blade clamp to the glass, worse than that of frame variants. Because of the design features of the best brush is pressed in its central part, but at the edges weakens. Suffers removal efficiency of mud and water from the glass.
However, it is better to work in the winter, as more resistant to the formation of ice crust, due to the fact that the water here is almost does not accumulate.
The feature special brushes heated
This version of the wiper blades is becoming more common and popular. Many drivers believe it is their ideal for the winter.
Such a statement may be partly justified, since this type of brush is not frosting even in freezing. Consequently, in any weather, they will effectively cope with the work, since the brush temperature will always be higher than the air temperature. This ensures that the rubber does not freeze, and therefore does not lose its properties. Even if the night the ice formed on the surface, after heating it rapidly melted. As we see, solid pros.
The design of wipers with heated fairly simple. The only difference is that the brush on the canvas is a thin heating element plugs into the onboard electrical system via a special relay.
And that is the need to connect the device to the onboard electric system and will be the main disadvantage of this type of brush. Since due to this installation of such structures is complicated and requires special skills.
Yes, and they are not suitable for outdoor use, as all the pros are not relevant. And are these wipers much more classical models without heating.
How well in cold running hybrid wiper blades?
Hybrid models-they combine the advantages immediately and framed and frameless designs. In fact, everything is very simple, takes the classic skeleton wiper blade and placed in a special protective case made of plastic streamlined shape, having a reliable seal.
This design ensures uniform pressing of the web to the glass, good streamlined and efficient removal of moisture, which ensures reliable protection of all the elements from corrosion. These brushes are less frosted in the cold.
But there are also a significant drawback-the high cost, they are often twice as expensive as its frame and frameless analogs
Summing up
The choice of the wiper blades in the winter-not an easy task. As you can see, they can significantly vary in their characteristics and performance properties. Therefore, to choose the driver is sometimes very difficult.
Analyzing all the above, we can conclude that for the winter best with properties suitable hybrid brushes and wipers with heated. The last is very important to connect if you do not know how to do it. If you are not sure, entrust the installation of better janitorial professionals.
Behind them on the effectiveness and reliability of the model are frameless and frame are best left for the summer.
Of course, when you buy be sure to look at the quality of materials and the reliability of the design. It is best not to risk it and do not take the cheapest model from unknown manufacturers. Since in this case the risk to get the goods of questionable quality. It is best to choose a wiper from well-known European and domestic brands of medium and high price category.
In our online store you can 130.com.ua buy wiper blades in Kiev, Kharkov, or Odessa delivery in Ukraine.
Related materials
Wipers: Best Sellers
