Installing speakers / speakers in the rear shelf
For rear speakers, mid-low-frequency loudspeakers are best suited. Here it is important to remember that you need to place the speakers so that there is still free space between them. As practice shows, the ideal option - the speakers in the back doors, and the subwoofer - in the trunk. But drivers are increasingly more likely to install a speaker system to install a speaker system, because this is easier in terms of installation work.
It is recommended to power the amplifier directly from the battery to minimize possible interference from the running motor. Installation in most cases is made on special podiums: these are the holes in the car's interior. In some cars they are already provided, in which case you need to adjust to the installed diameter of the speakers. If they are not present, then choose the podiums in parallel with the acoustics: then there was no problem with the compatibility in size.
Installation Sequence
Sequence of actions when installing speakers on the rear shelf of the car:
- Recline the seat for a comfortable motif.
- The lantern of the rear brake, which is located on the rear shelf, is removed: to do this, first unscrew the two screws.
- Marker (any) circle future holes for the columns: as a "markup" you can choose any convenient way for yourself.
- Remove the side racks. If you have a car with side curtains, you first need to fix the cap, remove it and only then unscrew the screw below it.
- With extreme caution, we remove the airbag.
- From the shelf, remove three clips and pull out the structure itself.
The work with the shelf is finished, now we start working with the wires:
- Remove the side racks so that you can connect the wires.
- Take care in advance to make the right holes for the diameter of the speakers.
- Connect the wires to the acoustics and tape them with electrical tape.
- We conduct wires under plastic.
- We collect the design back: pay attention to the safety of all the wires.
If installed correctly, the speakers will not make noise even on a bad road. Conversely, improve the sound quality of music and will load you into the atmosphere of your favorite tunes.
Buy autocabs with delivery to Kiev, Kharkov, Odessa and the Dnieper, and also to install it in the back shelf you can on 130.com.ua.
Related materials:
Car acoustics: Best Sellers
