Installing speakers / speakers in the front and rear doors
Not always the standard acoustics meets our requirements for sound, so we are faced with the problem of installing speakers / speakers in the front and rear doors. First, you must select the device itself for mounting. In addition to sound quality, also pay attention to the size.
If you stopped on the model of autoacoustics, which in diameter exceeds the standard connector, you have to increase this connector. As one of the options — spacer rings or expanding the area with a jigsaw. To obtain the best sound quality, it is also recommended to install a vibration-proof material on the door.
So, let's get down to the action
There is a small cap under the door handle, we remove it. There is a bolt under the hexagon next to it, it needs to be unscrewed.
— In the block where the buttons for controlling the window regulators and mirrors are located, remove the mat.
— Now unscrew the bolts under the hexagon: in the front there are three, in the back — two.
— We take out the control unit of the window regulators. Immediately disconnect the control terminals.
— Unscrew bolts inside the skin.
— At the bottom of the door we find two screws and also unscrew them
— Now carefully remove the paneling: we have to install it back. As additional fastenings still there can be clips or an elastic band.
— If there is a full-time acoustics, shoot it and fix it in its place with new acoustics.
Now you need to install the back cover, the power window control unit. To mount the speakers in the front doors, you can use double spacer rings: so, the sound will not go into the plastic skin. As a result, you get a quality, clean sound, even at high volume. Buy acoustics in the car in Kiev, Odessa, Kharkiv with delivery to Ukraine can be at 130.com.ua.
Related materials:
Car acoustics: Best Sellers
