TOP 5 heated seats. Heating rating 2023!
In winter, when the outside temperature drops below zero, every car trip can turn into a real challenge. Cold seats can not only be uncomfortable, but can also have negative health effects. At such moments, car seat heaters become a real salvation, providing warmth and comfort to both the driver and passengers.
This accessory is simply necessary in winter; it has great benefits; in particular, several important points can be highlighted:
- Increased comfort: When it gets really cold outside, nothing beats warm car seats. Heating creates coziness and comfort, making travel enjoyable even on the coldest days.
- Maintaining Health: Cold weather in winter can have a negative impact on your health. Heated seats help relieve tension and muscle spasms, improve blood circulation and prevent possible back and lower back pain.
- The ability to create optimal conditions in the cabin: Many models have the option of adjusting the heating temperature, the driver himself chooses how hot the seats will be. This allows you to adjust the maximum comfortable heat level according to your personal preferences.
In this article, we will look at the top 5 car seat heaters that will help you cope with the winter cold and make every trip comfortable and enjoyable. The following models are popular among our clients:
- Mitsumi M-1-0
- Milex Arctic Grey
- Qline Fiber UNI-U06
- Dometic MagicComfort MH 40S
- HEYNER WarmComfort Speed 504000
Mitsumi M-1-0
Mitsumi M-1-0 - reliable and effective seat heating with several levels of heating intensity. This model ensures even distribution of heat over the entire surface of the seat, making travel pleasant and comfortable.
Heated seats from Mitsumi are a convenient addition to your car, especially important in winter and cool periods of the year, when not only the car, but also the seats begin to cool down.
This heating is mounted under the seat upholstery, providing heating in both the back and the lower part. Heating mat size: 27 x 48 cm. Power for heating comes from the vehicle’s on-board electrical network. The heating elements are made of carbon fiber and have built-in temperature sensors to prevent short circuits and overheating.
The heating elements heat up to 35-40 °C and then maintain the temperature corresponding to the selected intensity.
Equipment:
- 2 heating elements per seat (back + seat)
- a button with two heating modes
Milex Arctic Gray
Milex Arctic Gray is a stylish and reliable heated car seat that is easy to install and connects to the car's on-board power supply, into the 12 V cigarette lighter socket. It provides fast and even heating of the seat, making every trip warm and comfortable.
These are full-fledged seat covers made of fabric that is pleasant to the touch. High quality wire heating elements are integrated into the covers. Unlike conventional heated covers, the covers provide a more reliable and tight fit on the seats, which prevents them from slipping or moving while driving. Installation is carried out by putting it on the seats and securing it using special hooks that are included in the kit.
The length of the power cable is 1.5 meters. The cable itself has a four-position switch to regulate the heating level, and also has a built-in safety fuse.
A unique feature of this kit is that it includes two covers at once - one for the driver's seat and the other for the passenger's seat. Their power cables come out from different sides: on the right side of the driver's cover and on the left side of the passenger's cover. The set also includes headrest covers. If your car has only one cigarette lighter socket, then the connection is simultaneously made through a special splitter.
Milex heated covers are universal and suitable for installation in any car.
The set includes 2 covers.
Qline Fiber UNI-U06
Qline Fiber UNI-U06 is a universal built-in heating for one seat, it is equipped with a carbon fiber heating element. The main advantage of this material is smooth and uniform heating, as well as the ability to cut the mat to the required size. If one of the wires is broken or damaged ov carbon fiber material, the rest will continue to work, which is an advantage compared to cheaper wire heating elements.
The heating elements have a size of 270x480 mm. They are easily mounted under the upholstery of the chair in the back and seat.
This heater is equipped with a built-in thermostat that automatically turns off the heater when the material temperature reaches 65°C. The maximum heating temperature is 48°C. Maximum power: 55 W.
Equipment:
- button with four heating modes
The Dometic MagicComfort MH-40S heated car seat cover is an excellent solution for creating the most comfortable conditions in a car during the cold season, especially if it is not equipped with a standard heating system. This seat heating is easy to install and provides a high degree of comfort. The cover is suitable for both cars with standard equipment and those with airbags integrated into the seat. It has a secure locking system that prevents the cover from shifting and ensures comfort during long trips. Size: 1000 x 450mm.
This model of heated seats is of high quality and safety. Made of high-quality material, pleasant to the touch (cotton with the addition of polyester). It has a built-in overheat protection system using a built-in thermostat. In addition, the design is designed to ensure reliable insulation of the heating elements. The cape is connected to the cigarette lighter socket; its operating voltage is 12 V.
Among the advantages of this model, we can also highlight 2 operating modes: fast heating and slow pleasant heating, and a convenient built-in mode switch.
Equipment:
- Zippered storage case
- Cape
- Instructions
HEYNER WarmComfort Speed 504000 is a reliable and easy-to-use heated seat. It is a comfortable cape with built-in heating elements that is attached to the car seat. This accessory is indispensable in winter, when the car seats can be very cold.
Heated seats operate from the vehicle's on-board network. To activate the heating, just connect the cape to the cigarette lighter using a special cable, and within a few minutes it will heat up and provide the necessary heat. Next, the device will maintain the optimal temperature automatically.
The large heating area ensures uniform heat distribution over the entire surface of the seat. The width of the cape is 44 cm, the total length is 91 cm, the back is 50 cm, the lower part is 41 cm. The cape is also equipped with an automatic shutdown system when the temperature reaches 65°C, which ensures safe use. This model is quite economical and consumes no more electricity than one turned-on marker lamp.
The set includes one cape.
Related materials:
Seat warmers: Best Sellers
