Call
TOP 5 car acoustics. Car acoustics rating 2023!
Car acoustics have become an integral part of our daily lives, turning every trip into a pleasant journey, as it allows you to create a great mood inside the vehicle. With the help of acoustics, you can make driving in a car as pleasant and unforgettable as possible. But how do you choose the best sound for your car?
When choosing speakers, you should pay attention to their size and compliance with the dimensions of the available space in the car. Speaker systems can be of various sizes, ranging from compact options with a diameter of 10-13 cm, medium - 15-18 cm and, finally, large ones with a diameter of more than 20 cm.
To get your speakers to perform at their full potential, you may need an audio amplifier, which can be an external device or built into your car's head unit. It is important to note that speaker sensitivity plays an important role: the higher the sensitivity, the less power is required from the amplifier to achieve the desired volume and sound quality.
Let's look at the five best car audio models that can satisfy even the most demanding music lovers. Our top 5 includes the following acoustic options:
JBL SPKCB 622
JBL is known for its high-quality sound, and the SPKCB 622 speakers are no exception. This model has a two-way configuration that includes a 6.5-inch woofer and a 1-inch tweeter. The system provides clear and rich sound, which is perfectly transmitted in both low-frequency and high-frequency ranges.
These speakers deliver professional in-car sound with high sound pressure levels for a vibrant music listening experience. The long-term RMS power rating is 60W, and the maximum power reaches 180W. This model has a wide frequency range from 48 to 21000 Hz and a high sensitivity level of 93 dB. The speaker basket is round in shape and measures 165 mm (6.5 inches) with a depth of only 45 mm. In addition, their design is sleek and beautiful, making them an excellent addition to the interior of any car.
The diffuser is made of polypropylene using universal technology. This material combines lightness and strength, providing excellent internal attenuation, preventing sound distortion. Additionally, it is UV resistant, making it reliable for long-term use. The unique speaker design allows you to adjust its position, which improves sound quality.
Installation is simple and convenient thanks to the universal design. These speakers are mounted in special standard places.
Hertz CK 165L
Hertz is a well-known manufacturer of audio equipment, and the CK 165 L is one of their best models. This is a component speaker with a 6.5-inch woofer and a 1-inch tweeter. It features good detail and rich sound, making it an ideal choice for music lovers.
It is designed to easily integrate and replace stock speakers in a variety of vehicle systems. The acoustics have a nominal RMS power of 100 W and a maximum power of up to 300 W, with an impedance of 4 Ohms and a sensitivity level of 92 dB. The frequency range is from 50 to 22500 Hz.
The woofer/midrange driver has an improved moving system and a compressed cellulose cone that provides an optimal balance between weight, stiffness and damping. The magnetic system consists of a ferrite magnet and a 25 mm voice coil.
The tweeter of this system has a soft Tetolon cone, providing a wide frequency range and high linearity. The low resonant frequency allows them to pair well with woofers and influences the height of the soundstage. The magnetic system includes a neodymium magnet and a 20 mm voice coil. The speaker has a modern and distinctly laconic design, which makes it easy to fit into the interior of any car.
This car speaker also comes with installation accessories, including protective grilles made of metal mesh and impact-resistant ABS plastic.
Focal ASE-165
French company Focal is renowned for its high-quality loudspeaker systems, renowned for their technological innovation, and the ASE-165 boasts impressive sound clarity and dynamics.
Acoustics ASE 165 is a component 2-way system that provides high fidelity sound reproduction information Includes a 16.5cm subwoofer with a polypropylene cone and an adjustable Mylar inverted dome tweeter for crisp highs and enhanced soundstage. The tweeter is designed for installation in windshield pillars or standard mounting locations.
These component speakers have flexible installation options and can be easily connected to a passenger car audio system.
This speaker system has high power and sensitivity, which guarantees outstanding sound quality, making it an ideal choice for both initial installation of an audio system and for upgrading existing speakers.
The driver bowl is made of durable steel, and the delivery set includes grills made of ABS plastic and Mesh, which not only improve the design, but also the technical characteristics of the speaker system. In addition, the black lacquered finish of the tweeter matches perfectly with the car interior.
JBL Stage2 624
Another model from JBL, Stage2 624, has even greater sound potential. It offers impressive bass and midrange reproduction, as well as balanced high notes. One of the advantages of these speakers is their frame design, which allows them to be easily installed in stock holes without the need to modify the vehicle or speaker design.
The JBL Stage2 624 is a 2-way speaker system that provides detailed sound even at high power levels and can be easily installed in standard car door locations and connected to a radio or external amplifier.
The technical characteristics of this car speaker system are impressive. Frequency range: from 55 to 20000 Hz, rated RMS power is 40 W, and maximum power is 240 W, which ensures high quality sound transmission without distortion. The sensitivity level reaches 91 dB. To unlock the full potential of the system, it is recommended to use an external audio amplifier.
The JBL Stage2 624 speaker system has undergone robust environmental testing to ensure its reliability. The woofer cone is made of durable polypropylene, which provides powerful sound and protection from damage. This system is able to satisfy the needs of even the most demanding lovers of high-quality sound.
Mystery MJ-520 Jadoo
Mystery is a brand that may be lesser known, but their MJ-520 Jadoo speaker offers excellent value for money. It provides clear and balanced sound when playing a wide variety of music.
This is a reliable coaxial 2-way speaker system that has a maximum power of 140 W and is capable of reproducing sound in the frequency range from 70 Hz to 20 kHz.
The MJ 520 speaker has a diameter of 5.25 inches (13 cm). The woofer features a high-quality injection-molded polypropylene cone and a 1-inch aluminum voice coil designed to withstand high-temperature conditions.
The tweeter has a diameter of 1 inch and provides high quality sound reproduction at high frequencies. The voice coil is cooled by ferrofluid, which helps manage thermal loads more efficiently. The result is bright and clear sound.
Related materials
Car acoustics: Best Sellers
