Recommendations for choosing acoustics in a car
Autoacoustics are also necessary for the driver, as well as a serviceable engine. In some cars such a device is included as standard, but it does not always provide high-quality sound of your favorite tunes. So, in order to choose the right car speakers, you need to first determine its appearance:
Types of Auto Acoustics
Coaxial is the simplest type of construction. There are several speakers in such devices and each of them operates at its own frequency. As the dividers are crossovers, which can go in a separate housing. Among the advantages can be allocated a large bandwidth coverage. Ideal for those who want to get quality sound without high system requirements.
Component - a choice for real connoisseurs of sound systems. Here, too, the frequency range is divided into several parts, and the same crossover is present. Their difference is that the speakers are made in different designs. One of the main advantages of such systems is the high quality of playback.
The choice depends on your preferences and mounting capabilities of your particular car. If you have installed regular speakers, then it is important that the new model came up to size. You need to pay attention not only to the diameter, but also to the depth.
Regarding the parameters, car column can be with a diameter of 10-13 and 16-17 centimeters. Car speakers with a diameter of 13 cm are suitable for those who prefer to listen to music at high frequencies. At 16-17 cm - those who put first place high quality sound.
As for power, then you need to follow one rule: this parameter should not be less than the output power of the radio. The higher this value, the louder you can listen to music and the better the sound will be. For maximum enjoyment of your favorite tunes, it is recommended to install the design on the front of the car. Buy car speakers in Odessa, Kharkov and Kiev at 130.com.ua with delivery to Ukraine.
Related materials:
Car acoustics: Best Sellers
