Dual Channel Combo Recorder – Playme OMEGA
Most of the combo recorders on the market can record video through only one channel. Therefore, if you need to remove something in the back of the car or when parking, the driver needs to install two separate devices – an auto-recorder and a radar detector.
The release of this model combo DVR eliminated the need to purchase two devices. In the two-channel recorder, Playme OMEGA combined:
1. Shooting in Super HD quality.
2. Supersensitive radar detector.
3. High noise filtering function.
4. Accurate GPS tracker.
In this review we will look at the main advantages of this device, we will indicate what its main features and additional features are.
External design and equipment
This combo-DVR has a relatively compact size relative to other similar devices.
- There is a patch antenna on the front, there is a lens near it, and it is made of several lenses.
- The panel part with connectors is located on the right side; there is a miniUSB for connecting the camera and the power jack. Connectors have G-like shape; it makes hidden installation in cars simpler. All wires are of sufficient length for convenient installation of the DVR.
- The picture displayed on a 3-inch color screen; during the period of driving, information from two cameras, speed control data, and other technical parameters displayed here.
- The picture view can switched; information from the rear camera will be interesting in order to view everything that happens behind the car. Priority can changed automatically by connecting the power line to the reversing light.
- Below the display of the DVR is a row of buttons with corresponding markings.
- Information recorded on a memory card up to 128GB. The presence of shooting on two channels and a high bitrate require a high-speed drive with class 10.
- In the upper part there is a mount with a vacuum suction cup, the recorder can rotated around an axis, changing the viewing angle for shooting.
The model of this model includes a retainer for installation on the windshield, an external camera, a cable for another camera, screws and the main body, as well as double-sided tape and technical documentation.
Device setup
The Playme OMEGA video recorder has separate tabs in the setting’s menu, which makes finding the necessary option easier. Also in more detail, you can adjust the characteristics of the radar detector and GPS tracker. Separately, you can select the duration and resolution for recording videos.
In the setting’s menu of the DVR, you can activate the function to control the distance to the vehicle in front. In addition, the driver can later view the captured information, apply protection or delete the necessary files.
Radar detector function
Video recorder Playme OMEGA can detect police radar operating in various ranges. This may be a set of arrows, cordon, and other devices. Its range is large enough, it provides enough time to reduce speed. When a camera or police radar detected, the signal strength and the range view displayed on the combo recorder screen.
The database updated regularly. Regarding the Avtodoria complexes, information about the entry and exit points displayed here; the driver will informed visually and by voice notification. The owner can adjust the volume by himself, as well as perform a thorough adjustment of the necessary parameters of the GPS-informer and radar detector.
Video recording
Information from two cameras processed using a powerful processor; a matrix installed in the body part and in the remote camera.
1. The quality of shooting Super HD, and speed – 30 fps. If desired, the driver can choose the quality of Full HD or HD. You can view the captured files without the need to install additional programs, other software.
2. Records have sufficiently high detail; induced sharpness is present throughout the picture. As a result, license plates from all lanes can easily distinguished. There is no noise or noise during shooting.
Filmed on the rear camera rollers recorded separately. There is a little less detail, but no less quality.
Playme OMEGA – great functionality and excellent quality of shooting.
The DVR of this model is an excellent solution for installation in the car. It differs, first, by the possibility of two-channel shooting, as well as by a good video quality. An ultra-sensitive radar detector and a GPS tracker installed here; they do their job no less qualitatively and accurately.
Installing this type of DVR is necessary, because with its help you can quickly determine whether there are police cameras or radars on the road and thus not be in an unpleasant situation. Moreover, the excellent quality of shooting with high details will help, if necessary, to prove their case. This car DVR can be bought with delivery in Ukraine to Kharkov, Kiev, Odessa at 130.com.ua.
Materials on the topic:
Video recorders: Best Sellers
