Stand-alone devices with 12 and 24 V mode
Imagine your frustration when you need to go quickly on business, but in the street you will find a car with a discharged battery. To get to your destination quickly you will not work. The situation is aggravated by the lack of connectivity to the power supply network.
The assistant becomes a stand-alone charger ( booster, jump starter). Such structures are not only able to start the engine, but also serve as a power source in the absence of battery or repair work. With it, you can maintain the on-board computer, alarms and other devices in working condition.
With one or more (depending on the model) sealed batteries, you can quickly start the engine and go on important matters. Such devices are equipped with a special card that monitors the battery charge. Pre-charging structures will be lifeguards in the absence of a power source due to its efficiency and autonomy.
During the selection you need to focus on:
- battery voltage;
- starting current;
- battery capacity.
Please note that the voltage of the battery and the device must match. Here keep in mind that the lower the air temperature, the more power will be needed to run. For example, for a passenger car on 2 liters. engine capacity will need approximately 250 amps of starting current. Trucks will require large values - starting current from 550 A.
Versatile are models for 12/24 V, because they are suitable for launching cars, as well as for more powerful vehicles and vehicles.
We recommend:
The starting current has two meanings:
- Peak-the parameter in the first millisecond of the start.
- Rated-the current in the first 3 seconds of starting the engine.
The higher the battery capacity, the higher should be the capacity parameter of the device itself. For example, 17 A/h is enough for a motorcycle, but for a truck it will be necessary to have about 44 A/h.
The number of starts is influenced by the capacity of the built-in battery of the starter charger and the degree of discharge of the battery. To use the device for professional purposes, it is better to give preference to a portable device with two batteries. So, you can drive about 10 cars at a time. Such models are effective in situations where you need to start several cars simultaneously in a short time.
We recommend charging starter charger after each work cycle. Charging from a fixed network is the most gentle process, which only prolongs the life of the device. You can buy a jump starter with delivery to Kiev, Odessa, Kharkov and throughout Ukraine at 130.com.ua.
See stand-alone video chargers
Materials on the topic
Starter-chargers: Best Sellers
