Automotive Articles - Seat Heaters
In winter, the life of the car enthusiast is gaining new momentum: having to leave the house earlier to warm up the car. Sometimes this can play a decisive role, for example, if you are late and you do not have time to wait until the salon warms up. But at the same time, who wants to go in a cold car?
In such situations, the ideal option is the presence of heated seats. This is an opportunity to locally warm up the salon, saving your time and getting the maximum effect. The choice of heated seats depends on the type of construction chosen:
Outdoor. Ideal for beginners and those who plan to permanently remove the device. It looks like a cape and covers, it works from the cigarette lighter. It does not require complicated assembly and is secured with special belts.
Built-in. It is installed under the seat cover, due to which requires at least minimal knowledge in the installation of structures. Works with the help of an onboard network. It is the most durable and practical option.
Models in the form of capes practically do not differ in external features, differ only in functionality. A heating element of different types can be used:
carbon fiber;
spiral covered with PVC;
teflon wire.
Seat Heating often has a power that does not exceed 100 watts. You can control the degree of heating with the help of special buttons, some models provide a separate console, which is fixed to the steering wheel of the car. The presence of a thermostat will prevent a possible overheating of the device.
Built-in heating kits are installed under the seat cover. The peculiarity of such devices is as follows:
A nihromic spiral covered with plastic is the most budgetary option. In some models it is necessary to pay attention that the heating does not intersect with the armature.
Carbon fiber structures are distinguished by high reliability.
One of the main advantages in the question of how to choose the heated seats of an embedded type is the insulation of wires and all elements, which prevents moisture and debris from getting onto the device. In addition, the installation of the structure does not affect the interior of the cabin.
It is recommended to choose models with the ability to adjust the temperature: the more options, the better. Some models are equipped with a timer, which automatically turns off the heating when a certain temperature is reached.
