Full HD recorder on Sony Exmor - top novelty from Gazer!
In the spring Gazer company announced the development of a new DVR on the Sony Exmor matrix - Gazer F140 , and recently it became known that the novelty will soon go on sale. The model has really decent characteristics both in software and hardware, and has all chances to become a top-quality solution for the quality of shooting.
The key advantage of the Gazer F140 is the use of the advanced Sony Exmor 1 / 2.8 "matrix in combination with the highest optical performance .The DVR is equipped with a wide-angle lens of 140 ° with focal length f=2.8 mm and aperture F2.0, and also has a WDR function, but about everything in order.
Of course, the use of the Sony Exmor matrix will allow the new Gazer F140 to justify the highest expectations from the quality of the image. In particular, this concerns video shooting at dusk and at night - strong photosensitivity with a minimum noise figure will provide an excellent recording result in case of insufficient illumination. In addition, the matrix from Sony successfully solves the problem of many car DVRs, namely - significantly reduces the level of "blurring" the image when driving at high speed.
As already mentioned above, in the new Gazer F140 matrix works in conjunction with high-end optics on the basis of a six-component glass lens. This will ensure high detail of small objects in the frame and good color rendering. Due to the large aperture of the F2.0 lens, the DVR is able to quickly capture a significant amount of light, which will significantly improve the image characteristics in low light. DVR buy in Kiev, Odessa, Kharkiv with delivery to Ukraine can be at 130.com.ua.
The entire positive effect of the resulting video is supported by the WDR (wide dynamic range) function. This technology has come to the segment of automotive electronics from professional video surveillance and consists in balancing the image over the light when shooting under extreme lighting conditions (bright light entering the frame, sharp lighting changes, etc.). For example, at the moment of leaving the car from the dark tunnel to the sun-drenched street on the video recordings from the registrar, we could see only the change of the darkened area to the illuminated area. In Gazer F140 this task is solved programmatically - and instead of "blind" zones on the video the user sees quite informative and readable areas.
As for the functional, the model received a practical and popular set of options among motorists. Automatic protection of "emergency" files from overwriting will be provided by the built-in G-sensor, as the user has the ability to manually block an important file from deleting by using a "hot" button on the case. For security recording, a movement sensor is provided in the parking lot in the device. Also, developers have prepared a pleasant surprise for active Internet users - the function Time-lapse shooting. With it, a video report about your journey can be made spectacular and memorable.
Ergonomics and convenience are also one of the strengths of the novelty. The DVR Gazer F140 is equipped with a rotary fastening system with a quick-release mechanism and a power supply function directly through the bracket. Thus, the user can easily and quickly change the direction of shooting, and it is also easy to remove the recorder from the mount. And installation / dismantling of the device will not be accompanied by regular connection / disconnection of the plug of the power unit. The model is made in a stylish compact case with excellent ergonomics and a large built-in 2.7 "display with auto shut-off function.It should be noted that the device installed on the windshield does not attract any attention to itself, and will organically supplement any interior of the car.
Like all Gazer autoregistrators, the novelty is equipped with a branded 8Gb Gazer microSDHC memory card, so the device is fully operational without the need to buy anything separately. In the event that the received video recordings will be used as evidence in the court, the presence of the state certificate of conformity of UkrSEPRO will provide additional legal weight to the materials. When exactly the novelty goes on sale it is still unknown, but it is expected that the Gazer F140 will be available by the end of the summer.
See video reviews of DVRs
Related materials:
Video recorders: Best Sellers
