A tiny bestseller with serious features: an overview of the Gazer F121 car video recorder
While other brands of car DVRs are presenting new products almost monthly, Gazer is more balanced in developing new models. As a result — every new device from Gazer becomes a hit, keeping confident positions in its class for a long time. Can you say the same thing about the last Full HD model — Gazer F121 ? Let's try to understand, but about everything in order.
Package Contents
The first distinctive advantage of the Gazer F121, which can not be overlooked, is a good equipment of the device. The standard set of models includes:
  • brand new 8GB Class 10 memory card
  • A special power supply with noise cancellation when the recorder and FM radio are operating simultaneously or the GPS-navigator
  • 2 interchangeable fastenings: on vacuum suction cup and double-sided adhesive tape
  • USB cable for transferring files to PC
  • Mounting clips for accurate cable laying under the lining of the cabin and on the silk screen of the windshield
  • A detailed user guide with clear wiring diagrams and a description of the functions of the recorder.
In addition, in the package you will find 2 stickers "Recorded video" for compliance with all rules of legality of video shooting, as well as a copy of the state certificate of UkrSEPRO. The availability of this document will be a significant legal advantage when using records from the DVR as evidence in the court.
Design
The dimensions of the Gazer F121 are only 69x43x24 mm, which is slightly larger than the standard matchbox. Even in such a tiny package, the developers managed to realize a 1.5 "diagonal display, with the option of auto-shutdown, as well as an ergonomic system of buttons and indicators.Even even a seemingly insignificant moment, like the location of the power connector and the length of the charger cord, the smallest details: the input for the charging plug is on the upper edge of the recorder, so that the power cable can be laid under the lining of the cabin, and the recorder on the windshield will look neat and invisible.
DVR Gazer F121
DVR Gazer F121
DVR Gazer F121
The case itself is made with a matte soft-touch plastic, which is not only pleasant to the touch, but also less prone to minor scratches, unlike conventional plastic. The combination of an interesting coating material and streamlined monobloc forms makes the Gazer F121 a stylish addition to the interior of any car.
Basic Functionality
The basic functionality of this model includes everything necessary for continuous operation with minimal user participation. It is enough to make the initial settings, install the device on the windshield, and in the future the recorder will operate in an unattended mode: automatically go into shooting mode when starting the engine, and also independently shut down when the ignition is switched off. In this case, video recording is carried out on a ring basis: when the space on the memory card ends, the recorder records the newest video instead of the oldest, without stopping the shooting.
For an important moment, besides the video recording of what is happening, the user has additional information, the rollers are titrated with the date and time, and for recording sound the model is equipped with a built-in microphone. It is also possible to make your own titles, for example, information about your car's number. This will make it easier to identify the record from the registrar when analyzing the controversial situation.
Additional Functions
Make the operation of the Gazer F121 as efficient as possible will allow advanced functionality. Thanks to the G-sensor, the model will detect any abrupt changes in the nature of the car's movement (impact, braking, acceleration), and then "lock" the current recorded video. The blocked video will be protected from erasure during ring rewriting, and the driver is calm for the safety of the most important video files. Enable the protection of the current movie can also be done with a hot button on the case itself.
In addition, the menu provides sensitivity adjustment of the G-sensor, which will be a very useful opportunity for driving on Ukrainian roads: you can adjust the sensor so that it does not work on every bump. Or vice versa — was especially "attentive" on ideal high-speed tracks. To perform the role of "watchman" in a parked car, the recorder is equipped with a motion sensor recording function (inclusion in the recording mode when a moving object is detected in the field of view of the camera).
An interesting and practical feature in the Gazer F121 is the presence of built-in 512 MB memory with the function of copying videos to the SD card and in the reverse order. This property is very useful in case you were involved in an accident and want the video from your registrar to be included in the list of evidences (included in the protocol of the SAI). To do this, an SD card with a record must be promptly provided to the traffic police officer directly at the scene. With Gazer F121, you can fulfill this requirement, and at the same time have your own copy of an important file.
Installing in auto
Gazer F121 is fixed on the windshield using one of the fasteners, to the user's choice, which we have already described above. Both mountings are very compact in size, which in combination with the miniaturization of the recorder itself gives an excellent result: the device is easy to hide behind the rear view mirror, it does not obscure the driver's view and does not attract unnecessary attention. So it does not need to be removed from the mount every time and installed again before the trip, for fear of theft.
DVR Gazer F121 in the car
A very convenient feature of the fastening structure itself is a swivel hinge system and quick-release mechanism. The logger rotates in any direction with one easy movement, and just as easily removed from the bracket. You can buy a car DVR in Kiev, Kharkov, Odessa at 130.com.ua with delivery across Ukraine.
Image Quality
The quality of Full HD video Gazer F121 can be called its absolute advantage. The device has everything to ensure that the user receives an excellent image with impeccable detail and color reproduction. The DVR is equipped with a six-layer glass lens, a 160-degree wide-angle lens and a 12-megapixel sensor. Such serious characteristics allow to achieve the highest quality of the picture under any conditions of illumination, including in cloudy weather and at night. So the problems concerning the difficulties of determining license plates of a neighboring car, road sign or traffic light colors, the owner of Gazer F121 will not be exactly.
See the video reviews of the DVR Gazer F121:
Output
There is no doubt that Gazer F121 deservedly bears the title of the top solution in the assortment of the brand. The first acquaintance with this model, like its further use, leaves only positive emotions. In addition to attractive design and a serious "filling", this recorder features a number of practical features and useful functions. At the same time, the manufacturer took care that the user did not need to buy anything extra and make another fuss: in the kit everything is provided in order for the registrar to be fully ready for work. In short, who wants to get a first-class device, a variety of functions and a complete package — this model will be a win-win option.
Related materials:
Video recorders: Best Sellers
