Automotive Articles - Automobile Refrigerators
A refrigerator in a car is an indispensable accessory for those who often go on long trips and those who leave for short trips but frequent trips. The device will help to keep a cold drink or favorite dishes at hand. Their compactness does not affect the power and functionality that we used to observe in conventional designs.
The question of how to choose auto-refrigerator, appears in connection with a wide range of such products, because each manufacturer tries to stand out from competitors , equipping their models with new functionality.
First, we determine the type of device:
Thermobox: does not provide external power. Cooling is obtained with a special battery. It is characterized by low cost, designed to maintain temperature. By the principle of work is similar to a bag-refrigerator, their difference is only in size.
Absorption: can be fed from both electricity and gas. If you use the second option, then the design will also be an economical option. Among the main features can be identified a large volume, which can reach 200 liters. It works silently: extraneous sounds will not distract you from the road. You can cool the food by 30 degrees, but the temperature below zero is not provided: it will not freeze. Ideal for fishermen and hunters.
Thermoelectric - a compact device, characterized by high reliability. Among the features can be identified the possibility not only to cool the products, but also to heat. A good choice for daily use on short distances.
Compressor - the most economical models that quickly cool down to the right temperatures. The mode of freezing is provided: the temperature is up to -20 degrees. You can independently adjust the temperature regime. If you turn off the device, the preset mode can last up to 6 hours.
The refrigerator in the car from the cigarette lighter will be a reliable assistant for transportation of food for a picnic, rest or from the cottage. The choice of auto-refrigerators is largely determined by the volume of the design, which depends on the number of people for whom you will transport food. So, for example, for one, enough and 5 liters, but for a large company will have to stock up 50 liters. Optimal - to fit a 2-liter bottle of water.
It is important to pay attention to the quality of the material: it must be resistant to mechanical damage and temperature changes. In connection with the probability of making sharp turns on the roads, it is important to provide a reliable fixation of the lid, which should not open independently.
Feature articles
How to Safely Transport Medicines, Vaccines and Baby Food in a Car Fridge
How to Choose a Car Refrigerator That Won’t Drain Your Battery: Comparison of Popular Models
How to Use a Car Refrigerator with a Power Station: Tips for Road Trips and Camping
How to Choose a Car Refrigerator in 2025 — Step-by-Step Guide for Road Trips
How a Car Fridge Affects Battery Health: Myths & Facts
Top 10 Car Fridge Mistakes and How to Avoid Them
Advantages of car refrigerators for travelers
Everything you need to know about compressor coolers
Features compressor Autorefrigerator
Types of car refrigerators: principle it working and features of
Types of cold accumulators and rules for their use
Practical tips on choosing a car refrigerator
The principle of operation of auto refrigerators
Test of auto-refrigerators Dometic WAECO
What to consider when choosing an auto-refrigerator?
How to choose a car cooler?
Wi-Fi car coolers: best models
Autorefrigerators: a bag or container?
Autorefrigerators heated!
Do not forget to buy Supra auto-refrigerators before the summer
