Автомобильные статьи — автосвет — за 2020 year
Auto Light - Selection Wizard
How to adjust the car's headlights, if they do not shine?
news_title
The drivers are often confronted with the fact that the lights suddenly start to look bad. Not always this is due to the need to replace automotive lamps. Sometimes the cause of poor illumination of the road-it is shot down control of lights, when they begin to shine than on the road, and down, up or to the side. To eliminate it is necessary to perform the headlight adjustment and adjust the correct position of the light beam. Make it is not difficult. all…
24.10.2020
Why dim light lamps? And how to deal with it?
news_title
On how bright car headlights depends on road safety. If the light from the lamps became dim and the lighting is not enough, it can lead to an emergency situation. This can not be tolerated. Therefore, if the headlight bad light, it is necessary to take appropriate measures to address the causes and solutions to this problem. all…
06.10.2020
The main parameters of LED automobile lights
news_title
What is so special automotive LED lamps, which can be found on the lamp, looking markings and learn its main technical parameters? What is Kelvin, Lux, Lumen? What do these options and what to look for when choosing a car lamps. all…
15.06.2020
Why do LED lights blink in the car?
news_title
On the road, you can sometimes see cars with blinking front and rear position lamps. Why do LED bulbs start flashing? We will consider the main reasons and tell you how to deal with this phenomenon. all…
08.02.2020
