Acoustic systems Pioneer 2019 – the best acoustics with more powerful sounding in your car
The novelties of acoustics from Pioneer, which are combined in the A series, are distinguished by the best external data and functionality. Updated acoustic systems have increased power and a wider frequency range.
The design dominated by classics, laconic colors; this acoustics is well suited to the interior of any car. So, let's consider the main characteristics of the new A series.
New power and sound quality – Pioneer TS-A1370F
Coaxial round acoustics TS-A1370F, presented by Pioneer, makes it possible significantly improve the playback of music at high and low frequencies. In addition, with the help of a special application CarSoundFit, you can feel, after installing the acoustics, a significant difference between the previous and real sound.
Features of Pioneer TS-A1370F:
- 3-way acoustics;
- Rated and maximum power 50/300W;
- The size is 13 cm (5.1");
- There is an IMPP diffuser.
The concept of Open & Smooth for creating super acoustics taken into account in this model. This allows you to get a clean and powerful sound. In addition, the built-in diffuser makes it possible to listen to music without distortion, enjoying the excellent sound from the dynamics.
New models, better features – Pioneer TS-A6960F
Pioneer presents new solutions of acoustic systems on a regular basis. Among the novelties – a new oval coaxial acoustic system Pioneer TS-A6960F, developed by the unique concept of Open & Smooth. With its help, acoustics gets new, more extensive possibilities – better sound, clean key at low and high frequencies.
Features of the model Pioneer TS-A6960F:
- 4-band equalizer;
- Frequency characteristics of 35Hz-24kHz;
- The dimensions are 163×237 mm (6×9");
- Rated and maximum power 90/450W;
- The availability of Custom Fit Adapter for expanding the installation and optimization of the device;
In addition, the application CarSoundFit allows you to feel the difference between the previous quality of sound and the one that will be after installing the acoustic system.
The best sound quality with Pioneer acoustics TS-A6970F
The updated version of the Pioneer TS-A6970F speaker system will be the best solution for your car. Saturated bass, excellent sound is possible due to good playback at low and high frequencies. In addition, the Pioneer TS-A6970F coaxial oval acoustics has the following functions:
- With a 5-band equalizer;
- The nominal and maximum power is 100/600W;
- Frequency range of 34-25 000 Hz;
- Equipped with IMPP diffuser.
The presence of special applications that used with the Pioneer TS-A6970F acoustics, allows you to analyze the quality and purity of the playback, as well as make a more powerful and rich sound.
The power of Bass Acoustics Pioneer TS-A6980F
A better sound obtained with the oval coaxial acoustics Pioneer TS-A6980F. It presented by Pioneer as a device with excellent performance of rated and maximum power. Its main functions are:
- 4-band equalizer;
- The power indicators are 100/650W;
- Frequency ranges – 22-24 000 Hz;
- It is equipped with IMPP diffuser.
Due to the excellent characteristics of the model, many connoisseurs of quality and pure sound choose. Wide frequency ranges, high power levels allow you to get a clean sound when playing music.
Enjoy the superb sound of your favorite music with Pioneer TS-A6990F
The latest model among the novelties of Acoustics A series – the Pioneer TS-A6990F features powerful sound reproduction with high and low bass frequencies. After installation in the car, you can feel all the advantages of this model: you get a high-quality sound with the versatility of the music you listen to. Functionalities of oval coaxial acoustics Pioneer TS-A6990F:
- 5-band equalizer;
- There is an IMPP diffuser;
- Rated and maximum power – 120/700W;
- Frequency ranges – 22-25 000 Hz.
This device is the leader in the acoustics market, with its performance indicators no other system compares. After installation, using the program CarSoundFit, you can test the device and feel all its advantages.
What novelties of the A series differ from other acoustics?
The manufacturer took care of its customers by making unique acoustics systems in this model range. They differ:
- The group of contacts transferred from the wide to the narrow part of the dynamic. This makes the use more convenient and simple;
- Improved the external qualities of each device. All the wires that were on the outside and the spike traces are secure and well hidden, the dynamics of the acoustics look perfect, without external flaws;
- For some models, an advanced speaker basket was developed. It has 3 points of support, instead of 4, which makes it more convenient to install.
In addition, each model packed in an updated package, which hosts the QR code of the online guide. After pointing at the smartphone, its display shows information about compatibility and recommendations for installing acoustics
On 130.com.ua you can Buy autoacoustics in Odessa, Kharkov, Kyev with delivery in Ukraine.
Related materials:
Car acoustics: Best Sellers
