New Pioneer review: 2017 acoustics
Pioneer introduced an updated version of the G-Series speakers. It received these enhancements.:
- more bass;
- increased power parameters;
- new packaging design;
- introducing the same grill design as the E series models;
- more collected scene.
Now your bass is under full control with improved devices from Pioneer.
Pioneer TS-G1010F
Pioneer TS-G1010F is a premium sound speaker system with a maximum output power of 190 watts and a nominal 30 watts. Differs in a good ratio of the price and quality. The woofer is made of composite IMPP material. This is an affordable solution to improve the sound of music in your car. IMPP Diffuser minimizes possible sound distortion. Weight is only 0.34 kg.
Pioneer TS-G1020F
Pioneer TS-G1020F is characterized by the presence of mounting holes and light weight (0.35 kg.) - you get a lightweight installation process devices. The system is designed to reproduce deep bass and natural sounds at high frequencies with high quality. Coaxial acoustics with a diameter of 10 cm and a nominal power of 30 watts will transform the usual sound of melodies, help you enjoy your favorite compositions on the road.
Pioneer TS-G1310F
Pioneer TS-G1310F - this speaker system with a diameter of 13 cm will allow you to enjoy plenty of high-quality sound of your favorite songs. The main distinguishing feature is the presence of a double diaphragm (230 W).
The installation depth is 44.3 mm, and installation is carried out using special hardware on the device. Rated power - 35 W, sensitivity - 89 dB.
Pioneer TS-G1320F
Pioneer TS-G1320F -coaxial acoustics with a frequency range of 33-24000 Hz. offers a new sound to old melodies. Reproduces deep bass and natural sound even at high volume. This two-way model has a rated power of 35 W and a maximum of 250 W.
The presence of an IMPP diffuser provides high-quality sound transmission without distortion.
Pioneer TS-G1330F
In acoustics Pioneer TS-G1330F absolutely everything: more durable and lightweight design with increased power and sensitivity parameters. Differs in a simple way of installation - with the help of two fasteners, while it has a small weight - 0.39 kg.
Model with a diameter of 13 cm and 3 bands provides high quality sound even at high volume.
Pioneer TS-G170C
Pioneer TS-G170C — component speakers with two mounting holes for easy installation. It features a lighter design with increased power and sensitivity. Reproduces deep bass and clear sound even at high volume.
The 17 cm two-way system has a rated power of 45 watts and a maximum of 300 watts. The presence of a diffuser minimizes possible distortion.
Pioneer TS-G1710F
Pioneer TS-G1710F — double diaphragm speaker system with a diameter of 17 cm. has a small weight: only 0.57 kg. It has good performance: nominal power - 40 W, sensitivity - 89 dB. Equipped with a double cone structure with a woofer made of composite material and a copper voice coil.
Pioneer TS-G1720F
Auto Acoustics Pioneer TS-G1720F — This affordable solution for high-quality sound in the cabin of your car. A coaxial speaker system with a diameter of 17 cm. Even at high volume provides clear sound without distortion. And all thanks to the presence of IMPP-diffuser.
The diameter of the installation hole is 144 mm., While there are two fasteners for self-installation of the device.
Pioneer TS-G6930F
Acoustic system Pioneer TS-G6930F provides maximum opportunities for providing the driver with high-quality sound: turn on the maximum sound and get your favorite songs without distortion due to the presence of the IMPP-diffuser.
Rated power-45 watts, maximum-400 watts. The frequency range is 32-32000 Hz. A good and affordable option for enjoying the sound of songs on the road. You can buy autoacoustics in Kharkov, Kiev, Odessa with delivery in Ukraine at 130.com.ua.
Materials on the topic
Car acoustics: Best Sellers
