Car Chargers-Car Battery Charging
"Seed" the battery... What could be more unpleasant surprise before the trip? If the battery charger is at hand, then the solution to the problem will not be difficult. A regular and correct use of it is a reliable means from such annoying "surprises."
A striking variety of existing options for storage batteries for today, united in its work principle, can be distinguished by some parameters. So, the charging method and the corresponding design features allow you to buy a charger of one of the two main types. The traditional transformer charger , which works without frequency conversion, is probably familiar to many. It is based on a powerful, but bulky and heavy transformer and rectifier, which essentially add weight and dimensions to the entire device. Today it can be an automatic charger that operates in a fully automatic charging mode with the stabilization of the power of charging current and voltage on the battery. As a rule, there is a possibility of smooth adjustment of charging current and voltage, visual indicators of their values (ammeter, voltmeter) and control elements of the device. Simplicity of design, reliability and availability of elemental base, absence of created radio interference, short circuit protection and incorrect connection polarity ensure the attractiveness of this type of device. But the large weight and dimensions (proportional power), metal capacity, weak protection against network fluctuations, and overheating do not work in their favor. Charging device for a battery to buy with delivery in Ukraine to Kharkov, Kiev, Odessa can be on 130.com.ua.
Then the subject of choice becomes a compact, easy and convenient alternative-the impulse charger . It is also based on a transformer, but of a smaller size with the same power output due to its operation with high-frequency pulsed currents. It also provides a pulse charger for a car battery and other winning advantages. Among them-the smaller size and price of the charger due to a unified element base, high efficiency and reliability, the presence of various built-in protection circuits. Modern impulse device-intelligent, fully automatic (although with the possibility of manual control) with convenient indication of the process of charge. But the formation of high-frequency interference and the complexity of repair are its weak points.
The existence of devices today, more versatile than conventional pulse or transformer chargers, extends their functionality. It is a start-charger that performs two tasks: charging the battery, and starting the car with a discharged battery (without pre-charging it) due to the ability to give a current several times larger than the usual charger. Prices, dimensions, and weight of such models, however, increase with this.
Contact us to buy a battery charger , which is longevity and effective work directly. on the quality, the correctness of the choice and application of the memory.
Materials on the topic
Starter-chargers: Best Sellers
