Choose an autocompressor: important features and top-5 popular models
Agree, Chinese goods bribe us at their own cost, but with the same lightning speed they disappoint with their quality. We will tell you how not to make a mistake with choosing a compressor, but at the same time to choose a budget device. Let's take a look at examples of the 5 best models.
Important selection characteristics
Maximum pressure. In general, in theory, for a standard car, the indicator in 2-3 atmospheres will be quite sufficient. However, only some compressors offer us such parameters, most are able to produce from 7 atmospheres. Such a value for a passenger car is more than enough.
Performance. Indicates how long the compressor will be able to raise the tire pressure to the desired value. There is one nuance: the higher the indicator, the higher the price. You can choose the most budget model, but with it you will pump the wheels for 10 minutes.
Manometer. Significantly simplifies the use of these structures. An analog or digital mechanism can be used. The main requirement is the accuracy of the indications.
Type of connection. There are models that work from the cigarette lighter, and there are those that connect directly to the on-board network. It is more practical and more convenient to buy compressors that function from a cigarette lighter. The second option is only used in cases where more power is needed.
Cord and hose length. This parameter affects the usability of the compressor. At a minimum, the length should be enough to reach all the wheels of the machine.
Additional functions. Manufacturers like to offer "new", "improved". Often these concepts are identified with the presence of new functions. And indeed, some of them are very useful:
The lantern will facilitate work with the compressor in the conditions of absence of illumination.
- — The "Autostop" function allows you to set the required parameter and not to control the operation of the device: it will turn itself off.
- — Protection from overheating prevents possible damage.
- — The presence of adapters allows you to use the design with other objects.
- — The availability of these features is not necessary, but they will improve the comfort and safety of the operation of compressors.
Top 5 popular models
Two-motor compressor Ring RAC640
Equipped with two compressors: piston - for car tires, rotary - for boats, mattresses, balls, etc. There is a function of hitchhiking. Powered by a cigarette lighter. The housing has a special place for storing the hose and adapters. For more comfortable work, a LED flashlight is provided. Features:
- — twin-engine: piston and rotary;
- — engine with cooling system;
- — digital manometer;
- — autostop function.
VOIN VL-720 OFF-Road Master with receiver
This is a powerful model that can give out as much as 100 liters per minute. The device can be used not only for cars, but also for boats, pneumatic tools, etc. Features:
- — 10 L Receiver;
- — piston protection system in the form of an external air filter;
- — powerful supports for stationary installation;
- — pressure - up to 14 atmospheres.
Car compressor Berkut R17
A practical and compact model that will become a true helper for any car owner. Suitable for passenger cars and SUVs. Despite its small size, it offers good power. Features:
- — connection to the on-board network;
- — gauge presence;
- — is equipped with an extension hose;
- — capacity 55 l / min;
- — pressure - 12 atmospheres.
Elegant Force Maxi 100 090 for jeeps and minibuses
It is a universal compressor that can pump from a conventional mattress to a jeep or minibus. Features:
- — Improved case with plastic inserts: the device does not overheat;
- — operation from an on-board network;
- — long hose - 7,5 m;
- — capacity - 60 l / min
Elegant Force Plus 100 043 with manometer
A reliable budget model. Useful for pumping tires and sports equipment. Features:
- — rotary motor;
- — productivity - 35 l / min;
- — overload protection system;
- — a storage bag is provided.
Your choice depends on your preferences. Someone value the price, others - additional functions. First of all, be guided by the performance and reliability of the design.
Autocompressor buy with delivery across Ukraine to Kharkov, Kiev, Odessa it is possible on 130.com.ua.
See video reviews of auto-compressors
Compressors and pumps: Best Sellers
