How to choose a speakerphone
Everyone knows that using a mobile phone while driving can cause an emergency on the road. But what to do when driving you need to answer an important call? For safe and convenient use of a mobile phone, there are special hands-free devices in the car. With their help, you can answer calls without being distracted by the phone itself; you don’t even need to pick it up, which is why such devices are often called Hands Free.
Speakerphone is very easy to use-you need to sync your device with your mobile phone once In the future, the Bluetooth speakerphone will automatically connect to the phone (when Bluetooth is turned on). You can answer calls with voice commands.
The main components of a car speakerphone are voice control, a sensitive noise-canceling microphone, a built-in battery and a wireless connection. Bluetooth hands-free can be bought in Kharkov, Kiev, Odessa with delivery in Ukraine at 130.com.ua.
When choosing, you need to pay attention to the type of mounting device, the presence of the display and the number of supported SIM-cards.
Mount Type
To select a Bluetooth speakerphone based on the type of attachment, click on the corresponding image.
More information about attachment types
Bluetooth speakerphone is installed On the dashboard/windshield using a special bracket on the suction cup or double-sided tape.
Some Bluetooth hands-free models have a snap fastener to install On the sun visor. The advantage of this mount is that it does not take up too much space on the dashboard or windshield of the car. In addition, when mounted on the visor, the speakerphone microphone is located closer to the driver and due to this, the quality of communication and the audibility of the interlocutor driver are improved.
Display
To select a Bluetooth speakerphone, based on the presence of the display, click on the corresponding image.
More information about the display
There is no need for a Bluetooth speakerphone (handsfree). It can be used to configure settings, dial a phone number, or, for example, scroll through tracks in a playlist.
Speakerphone without a display also has all of these features and capabilities, but control is done through voice communication and a special joystick. In such models, you can receive or make a call using voice commands. All device parameters are voiced.
Number of simultaneously working phones
To select a Bluetooth speakerphone based on the number of phones connected simultaneously, click on the corresponding image.
More information on phone support
Up to 10 different phones can be connected to modern Bluetooth hands-free models, but only one or two phones can be used at a time.
The advantage of a speakerphone with support for simultaneous use of two phones is obvious-when you connect two phones, the speakerphone will automatically determine which number the call comes in and will receive the call from it.
The lineup
Materials on the topic
