Choosing a car compressor is easy!
The current time is very different from the previous one in that humanity has achieved automation of a multitude of processes. Of course, the car fell into this list, since we all see that it became not just a means of transportation, but a separate world for its owner. That is why, today, there is a whole set of accessories for cars that provide comfort to the driver and passengers, and therefore should be every motorist. In this article, we will talk about an auxiliary device such as a car compressor and pumps.
For sure, everyone has an idea how to use a regular old pump (hand or foot) and what it is like to pump air in small jerks. Such a model could get from the older generation, however, this is already the last century. To date, we have the opportunity to perform the same work, applying much less force. The autocompressor for tire inflation is a special electrical device that easily copes with a lowered wheel and is indispensable on a long journey.
If you are a prudent driver and decide to buy an autocompressor, then in order to choose the best option for you, you should know, elementary, what types are and what you should pay attention to when buying.
An electric automobile pump produces mainly several types: diaphragm, piston and rotary.
Membrane compressor
This type of device has a simple design and easy to operate. Air injection is carried out due to membrane oscillations. The advantage of this type is considered to be the absence of moving parts, and a rubber sheet is the only thing that can fail. However, it is precisely because of the rubber membrane that it can be difficult to use during the cold season, because at low temperatures, the material freezes or loses elasticity. Speaking of its performance, which is a key quality, the indicator is less than, for example, a piston unit.
Piston compressor
Air injection occurs due to the operation of the cylinder-piston system and consists of an engine, a gearbox, and a piston pump with a cylinder. This type is characterized by high performance and reliability.
Rotary compressor
Such an electric pump is characterized by high performance and reliability, if compared with other types, but not common in the market due to the very high price.
Key Features:
Performance. This indicator shows how quickly and easily a device can do its job. Measured in liters of air that is injected per minute. The choice should be made based on the radius of the wheel. The heavier the car, the more powerful the autocompressor is required for tire inflation:
- cars (wagon, sedan, subcompact)-30-50 l/min;
- SUVs-50-70 l/min;
- cargo-70-160 l/min.
Pressure. Pick up the device according to your vehicle's tire pressure. For most, 2-4 atmospheres will be enough, but for off-road vehicles and trucks, 8-10 atmospheres need to be injected.
Advanced options:
Connection Type. Manufacturers offer options that work on a car cigarette lighter and are such that they are equipped with crocodile clips to avoid possible overloading of the onboard power grid.
Pressure gauge and graduation. This item measures tire pressure. To date, you can meet the analog and digital type. The best option is considered a digital pressure gauge, as it is not subject to vibration from the compressor and displays more correct data. It is worth mentioning that measurement accuracy is extremely important and it will be correct if you check the correctness of your device’s indicators with the instrument at the service station. In this case, the best division price is 0.1 atmospheres.
Additional tips. Various adapters significantly expand the scope of application, since they allow using the compressor for inflating mattresses, balls, rubber boats and other products.
The reliability of the material of the product. What would autocompressor tire inflation served for a long time, and you no longer returned to this issue, then definitely give preference to a device made of an alloy with aluminum or other quality material. In most cases, when a piston or cylinder breaks, the compressor cannot be repaired.
Important Details:
- Certificates and warranty cards.
- Auto-stop function. The device stops working after the necessary pressure is recognized.
- Bleed valve. During car operation, there are situations when it is required not only to create the necessary pressure, but also to relax it. With this feature, you can easily reduce tire pressure to the required level.
- Weight and dimensions. The autocompressor for tire inflation is a necessary and practical device and, as a rule, it is carried in the trunk of a car. Consider where you will store the electric pump, whether its size and weight are suitable, as there is no desire to clog the trunk of the car with a bunch of large-sized accessories.
- Cool function. The device may noticeably heat up during operation and requires interruptions in operation for cooling.
- Protective system. The compressor shuts off automatically when overloaded.
- Battery. The presence of a battery allows the compressor to operate autonomously, but the charge is enough to pump two or three wheels.
- Air exhaust. The ability to blow away a boat or mattress.
- Cord length. Pay your attention to whether there is enough space for connecting to all the wheels of your car, especially if you have a long vehicle.
- Stability while running.
- Backlight during operation and a flashlight (including a signaling flashlight).
- Air filter. Dusty and waterproof-assessed when they are used in the field.
The modern market offers a huge selection of models, but to buy a good car compressor, you should take into account your needs and compare them with the device parameters. Find the best combination of features and buy an autocompressor for tire inflation in Kiev, Odessa, Kharkov with delivery in Ukraine you can on site 130 .com.ua.
Materials on the topic
Compressors and pumps: Best Sellers
