TOP-3 Chargers 2017
Chargers are presented in a wide range on the car market, by the principle of operation they can be divided into two categories:
Chargers: gradually charging the battery, the current output is not higher than 8A;
Start-charging: designed for short-term pulse to quickly start the car without fully charging the battery.
All devices are distinguished by the presence of additional functions. For example, there are models with manual adjustment of current-they will cope with batteries that have long been in a discharged state. Automatic structures after charging go into standby mode, lowering the charging current gradually.
Best Chargers-Comparison Chart:
  1 place 2 place 3 place
  Pulse charger AIDA 10s 12 V, 10 A for gel and lead-acid batteries with 3 desulfation modes AIDA 10s Buy Pulse charger AIDA 11 12 V, 10 A for gel and lead-acid batteries with desulfation mode AIDA 11 Buy Charger Elegant Plus 100 430 6 A for car battery and motorcycle Elegant Plus 100 430 Buy
Voltage 12V 12V 6/12V
Maximum Current 10 A 10 A 3.5 A
Power 150W 180W 64W
Advanced 3 desulphation modes, several levels of protection, pre-start mode, for batteries up to 180 A/h Desulphation mode, 4 levels of protection, manual control of charging current, for batteries up to 180 A/h LED charge indicator, extra protection, for batteries up to 120 A/h
AIDA 10s Charger
  • ★ 3 desulphation modes
  • ★ For gel and lead acid batteries
  • ★ Compact size
  • ★ Controlled charge current
  • ★ Multiple levels of protection
Buy
First place
1 PLACE
Designed to charge batteries with a capacity of not more than 180 Ah. This is an automatic model, so it is suitable for beginners and those who have not previously had experience in setting up and managing such devices.
Can be used for cars, echo sounders, trucks. The rear panel is equipped with a special switch that provides a voltage limit of 0.2-14.8 V.
Able to replenish the charge of acid, helium and alkaline batteries. Differs in cyclic charge algorithm:
1A-lights, children's cars, motorcycles;
5A-passenger cars;
10A-trucks and engine start.
There are three desulphation modes: gentle, cyclic, intense.
Pros:
  • + Charge batteries that are discharged to 0 with short pulses;
  • + Equipped with prestart current;
  • + The presence of additional protective features that increase the safety of using the device.
Cons:
  • - Short power cord.
AIDA 11 Charger
  • ★ For batteries with a capacity of up to 180 A/h
  • ★ Compact size
  • ★ Manual control of battery level
Buy
Second place
2 PLACE
Designed specifically for proper charging of AGM, gel, multi gel batteries. It is possible to self-adjust the charging current and the recovery function of old batteries that have not been used for a long time.
Designed to charge a 12V battery with a capacity of 180 Ah. A distinctive feature of the model is the presence of a switch on the back panel, which can limit the charge-off voltage.
The device is also equipped with additional security features:
- overload;
- from overheating;
- from short circuits;
- from excess voltage.
Pros:
  • + Manual charge current adjustment
  • + Desulphation Mode
  • + Pre-launch mode
  • + 4 types of electronic protection
Cons:
  • - There is no special place for storing wires.
  • ★ Low price
  • ★ Comfortable design
  • ★ Versatility
Buy
Third place
3 PLACE
Elegant Plus 100 430-different comfortable way to control through a convenient design. Equipped with a transformer power supply, which makes the charging device heavier, but everything is compensated by a convenient carrying handle.
The charging current can reach a parameter of 6A — enough to charge a battery with a capacity of no more than 120 Ah. The ammeter here is replaced by a convenient light indication. To increase security, protective functions were provided against improper connection (especially important for beginners) and short circuits. A good and practical option for owners of cars and motorcycles.
Pros:
  • + Convenient carry handle design
  • + Versatility: can be used for motorcycles and cars
  • + Automatic control method
  • + Additional security features
  • + Low price
Cons:
  • - Enough weight: 1.6 kg.
Chargers are almost the basic necessities. Their presence simplifies the life of the driver, because you do not need to constantly contact the car service center to charge the battery, especially if it’s freezing and the charge level drops faster. The presence of a built-in battery in the chargers will allow you to solve the problem of a discharged battery very quickly, for example, if you need to go to work. Looking for a charger? Buy in Kiev, Odessa, Kharkov, you can at 130.com.ua. Delivery in Ukraine.
Watch charger videos:
Materials on the topic
Starter-chargers: Best Sellers
