TOP-5 starter chargers for auto 2017
A car charger is a lifeline for car owners when the battery is low. It can be useful during a long journey, in the cold or just when the battery has been inoperative for a very long time. You can buy a charger in Odessa, Kharkov and Kiev at 130.com.ua with delivery in Ukraine.
Most models are equipped with all necessary protection systems for safe use of devices. For example, from the wrong connection, short circuit. ROMs differ in functionality, technical characteristics, application complexity. The rating will allow you to choose the most suitable model.
Best car start-chargers-Comparison table:
1 place | 2 place | 3 place | 4 place | 5 place | |
Voltage | 12V | 12/24V | 6/12V | 12/24V | 12/24V |
Starting current | 80 A | 280 A | 100 A | 700 A | 100 A |
Maximum current | 30 A | 40 A | 15 A | 105 A | 45 A |
Advanced | For batteries with a capacity of up to 500 Ah; protection against overload, overheating, short circuit and incorrect polarity connection | Suitable for both prof. use (every day) and for motorists. Automatic protection when polarity is not observed. | Charger ZU-40140 is designed to charge DC-powered lead-acid batteries in cars | charge timer; remote control starting device; 4 modes of operation | Designed to charge rechargeable lead-acid batteries and start the engine during the cold season |
AIDA 30 Start-Charger
- ★ For batteries with a capacity of up to 500 A/h
- ★ Battery storage mode
- ★ Desulphation Effect
This is a practical device with a capacity of 900 W will launch the battery of any passenger car. The engine starts in safe conditions for the onboard computer-up to 13 V. The effect of desulfation is provided. The required mains voltage is 220 V.
Offers three modes of operation:
• battery charge;
• Startup Mode;
• Buffer.
Designed to work with batteries with a capacity in the range of 6-500 Ah. With a small weight and compact size is high performance. ROM is equipped with all necessary protective systems for safe operation. So, you can not be afraid of the consequences of a possible improper connection or surge in the network.
- + 6 protection systems;
- + Desulphation Mode;
- + Compact: only 1.5 kg.
- - Outdated design.
Start-Charger Ring RCBT40T
- ★ Fully Automatic Start-Charger
- ★ Two charge modes
- ★ For car enthusiasts and professional use
This model is rightfully takes its honorable Second place. Differs in the principle of work-the pre-charger is fully automatic. Connect and forget. Everything fit in a rigid metal construction: high power, functions, performance.
Suitable for daily use. You can work with all batteries with a capacity of up to 400 Ah. There are four levels of charge in the range from 2 to 40 A. It operates in a voltage of 220V. Provides protection systems from improper connection. Indicators show charge status.
Note also a convenient design: despite its high overall dimensions (21 kg.), easy to operate due to the handle and wheels.
- + Automatic operation;
- + Suitable for professional use;
- + Convenient type of construction;
- + Good wire length - 1.8m;
- - Large size.
Starting-charging device Tesla ZU-40140
- ★ For batteries with a capacity of up to 200 A/h
- ★ Continuous recharging function in connected state
- ★ Compact shockproof housing
You need to quickly drive off on business, but the battery does not have enough power to start the engine-familiar? With this problem, the Tesla ZU-40140 ROM will cope. And this is an option for owners of service stations or those at whose disposal not only a passenger car, but, for example, also a minibus or motorcycle.
Charge lead-acid cars with a voltage of 12 or 24V. The main protection systems are from improper connection, short circuit, overheating or overcharging. Compact case is easy to use and protected from mechanical damage.
- + The presence of protective systems;
- + Arrow ammeter;
- + Versatility of use;
- - Heavy enough device.
Starting-charging device DECA CLASS BOOSTER 5000
- ★ Charge Timer
- ★ Start Controller
- ★ 4 modes of operation
4 PLACE
Professional ROM, which instantly starts the battery of any heavy vehicles. Suitable for use in car parks and car companies. You can run up to 15 batteries without interruption at maximum power-do you feel the full power of this device?
The battery capacity should vary within 35-900 Ah, the effective current is 105A. Of course, there are several protection systems: from incorrect connection, overload, voltage drops. Suitable for 12 and 24 volt batteries. Even parallel charging of two batteries is provided, but their capacity should not exceed 800 Ah each.
6 charge levels-select the most suitable for your design. Charging timer for 1 hour will allow you to connect the device and leave to do other things. Cable length-2 m: convenient to use.
- + Availability of transport wheels;
- + 100% safe operation (multiple protection systems);
- + Multifunctional device.
- - Large size.
Starting-charging device Pulso BC-40155
- ★ For batteries with a capacity of 20-300 A/h
- ★ Analog battery charge indication
- ★ IP20 protection
5 PLACE
This reliable device is designed for lead-acid batteries and starting the engine during the cold season. Can be used universally: for passenger cars, trucks, SUVs, minibuses, etc.
Reliable components, high-quality assembly of the structure-all this allows for daily use of the device with a long service life. Provides protection systems. You can not be afraid of the circuit, the consequences of improper connection or overheating.
- + ROM versatility;
- + Analog charge indication;
- + Robust metal housing with IP20 protection;
- - No additional security levels..
Whatever your choice in the end, each model presented will serve you for a long time, will provide the battery with a charge and help you start the batteries, which have long been out of service.
Watch charger videos:
Materials on the topic
Starter-chargers: Best Sellers
