TOP-5 jump starters for cars of 2017
Low temperature, less light day, permanent lights, the use of additional heating systems-all this contributes to the accelerated discharge of the battery. And it's good if there is a car service nearby, but what if not? Then the autonomous starting-charging device (battery booster) should become an obligatory component of your garage and salon.
Their main difference is the ability to supply a higher current for starting the battery and without the need for a preliminary charge. "Revive" the battery, which had long been lying in the garage without work. Due to such popularity of designs, their range is also increasing: each manufacturer wants to offer the best to the buyer. We offer to get acquainted with the TOP-5 jump starters of 2017.
Best jump starters for cars-comparative table:
| 1 place | 2 place | 3 place | 4 place | 5 place | |
SmartBuster T242 Buy |
GT S21 Buy |
GT S8 Buy |
GT S12 Buy |
Einhell CC-JS 18 Buy |
| Voltage | 5V/12-16V | 5V/12V/16V/19V | 5V/12V/19V | 5V/12V/19V | 5V/12V/19V |
| Starting current | 1000 A | 750 A | 400 A | 400 A | 600 A |
| Capacity | 20 Ah | 21 Ah | 8 Ah | 12 Ah | 18 Ah |
| Advanced | Equipped with an output for a smartphone, terminals for connecting the battery, a protective system MultiSafety Protection 2.0 | Starting engines with a volume of more than 4 liters, signal lamp with 4 modes, intelligence. terminals with protection | Convenient carrying case, only 16 mm thick, flashlight with 3 modes of operation, 4 color options | Convenient carrying case, LED flashlight with 3 modes of operation, charge indicator, several USB connectors | Start-up wires with overload protection, protective storage case, several USB connectors |
Standalone Charger Start SmartBuster T242
- ★ Availability of a powerful LED flashlight
- ★ Large battery capacity
- ★ Starting engines on gasoline and diesel engines up to 8 liters
The multifunctional battery charger is a portable rechargeable battery in the form of a Power Bank. With it, you can easily charge motorcycle equipment, boat, equipment for working in the garden or a car with an engine capacity of up to 8 liters. With it, you can also resume the work of a tablet or smartphone, camera or camera, another gadget. Additionally equipped with a flashlight, can be used as a backup source for lighting.
Among the important technical advantages is the presence of several levels of protection - from overheating, short circuit, overvoltage, overcurrent or reverse connection. It has a solid construction, can continuously work perfectly at temperatures from -20 to +60 degrees
- + availability of an outlet for connecting a telephone, other devices, as well as a set of terminals;
- + equipping with a very bright and powerful LED flashlight;
- + The presence of a protective system MultiSafety Protection 2.0;
- + the presence of an intelligent system of integrated type.
- - only 2 USB connectors.
One of the most powerful representatives of portable starting and charging devices. It will help to start any vehicle, as well as other devices: gadgets, laptops, electronics. All this was made possible thanks to the large capacity-21000 mAh.
It starts up engines with a volume of more than 4 liters, because it has a starting current of 400 A, and a peak of 750 A. The manufacturer has paid attention even to such seemingly trivial things as the connection wire. This element is made of high-quality copper with a length of 30 cm.
The main advantage of the GT S21 is the ability to use it as a portable charge. The device charges any electronics and technology: it is equipped with two USB inputs and a DC connector for this.
As you already understood, this is a multifunctional device. In addition to its main task-to charge, it is also capable of lighting. Such an opportunity will help out in any situations on the road, for example, if you need to repair a car, and it is already night and there is no light source nearby. Two LED lights provide a bright stream of light for all situations.
- + Small size and weight: only 0.5 kg;
- + Resistance to temperature and mechanical damage;
- + The presence of LED lights;
- + Ability to use for cars and other gadgets;
- + Availability of a display with basic information.
- - Only 2 USB connectors.
This is a universal start-charger. It has such characteristics: starting current-200 A, peak-400 A, capacity-8000 mAh. Such parameters allow you to use it for boats, motorcycles, any equipment and gadgets, and of course vehicles.
It is worth noting the wire device: it is flexible and durable, made of high-quality copper with a cross-sectional area of 5.5 mm. In addition to the main task-starting the engine-the jump starter can serve as an external battery: charge the phones, player, laptop and everything at your fingertips. A USB cable is provided for this.
Improves the comfort of using the GT S8 presence of LED flashlight. It has a good range of lighting and several modes of operation. So, you can repair the car even in low light conditions or without difficulty connect your device to the charging when the lights are off. SOS mode is provided: gives a signal for help.
- + Compactness: only 10 cm. In length and 8 - in width;
- + Robust housing with reliable resistance to mechanical damage;
- + Availability of additional adapters;
- + LED flashlight with SOS function;
- + Multiple mailing options;
- - Small capacity.
- - Only 1 USB connector.
GT S12 Stand-Alone Charger
- ★ Capacity-12 Ah
- ★ Starting Current-400 A
- ★ LED torch with 3 modes of operation
4 PLACE
This is a compact start-charging device: only 16 cm long and 8 cm wide and weighing 420 g. It will charge not only the vehicle engine, but also any other equipment: from a smartphone to a laptop or a car cooler.
The battery capacity is 12000 mAh with a starting current of 200 A, and a peak-400A. Such parameters provide fast start-up and battery charging. The presence of the LED flashlight improves the comfort of using the GT S12: constant light mode, flicker and SOS function.
- + 3 USB connectors;
- + LED-lamp with multiple modes of operation;
- + Ability to use as a portable device.
- + Charge indicator.
- - Large size.
Standalone Einhell CC-JS 18 Starting Charger
- ★ Capacity-18 Ah
- ★ Starting Current-600 A
- ★ Power Bank feature
5 PLACE
Compact start-charger, which is useful in any situation on the road and not only. It will help bring back to life the batteries that have long been in the garage idle. And all thanks to the high capacity-18000 mAh and the starting current of 300 A-in just 5 seconds.
Equipped with an optional LED flashlight with several modes of operation: permanent, strobe and emergency lights. Jump-starter can be used not only for car batteries, but also for charging phones, laptops and other equipment.
- + Compactness: only 600 g;
- + LED torch;
- + Universality: for the HARDWARE and other electronics;
- + Availability of adapters;
Jump starters (battery boosters)-this is, indeed, an indispensable thing for the modern car owner. It will always help to have a charged car battery and help out if the phone is suddenly dead. And the device does not take up much space: it will fit even in the glove compartment or in the back seat. It is possible to buy a jump starter in Kharkov, Kiev, Odessa with delivery in Ukraine on 130.com.ua.
Watch charger videos:
Materials on the topic
Starter-chargers: Best Sellers
