2017 TOP 5 Smart Chargers
Batteries do not always work the way the manufacturer intended, for example, they are often discharged, so the driver has an urgent task: to solve this problem in a short time. To do without intellectual storage, especially in winter, is almost impossible. After all, a discharged battery is a real car.
Some models can be equipped with useful functions: desulfation, restoration of exhausted batteries, automatic charging, special winter mode. The main advantages of such models are compactness and ease of operation.
Best Intelligent Chargers-Comparison Chart:
| 1 place | 2 place | 3 place | 4 place | 5 place | |
Auto Welle AW05-1204 Buy |
Ring RESC612 Buy |
CTEK MXS 5.0 Buy |
Ring RESC605 Buy |
Daewoo DW 450 Buy |
| Voltage | 6/12V | 6/12V | 12V | 12V | 6/12V |
| Maximum Current | 3.8 A | 12 A | 5 A | 5 A | 4 A |
| Advanced | LCD display, 5 charging steps with desulphation mode, degree of protection against moisture and dust according to IP20 | Built-in battery test modes (starting power + cold start CCA) and generator; 7 stages of charging; power supply mode; protection class-IP65 | 8 stages of charging; battery and generator diagnostics; in the set-"crocodiles" and ring terminals; moisture protection class-IP65 | 7 stages of charging; in the set-"crocodiles" and ring terminals (with anthers); rubber enclosure with protection class-IP65 | 9 charging steps; battery diagnostics; memory mode (12 hours); moisture protection class-IP65 |
Intelligent Auto Welle Charger AW05-1204
- ★ LCD display
- ★ 5 charge levels
- ★ Suitable for lead-acid batteries
The intelligent charger is designed for all types of lead-acid batteries, as well as for AGM and GEL type batteries, which are used in commercial cars and motorcycles.
The presence of an embedded processor allows you to make the charging process fully automatic. There are several types of protection for increased safety of the device: from overheating, short circuit and incorrect connection.
With the display, you can get information about the charging process.
- + Automated charging process;
- + Prevent overheating;
- + LCD backlit display.
- - Lack of storage bags.
Intelligent Charger Ring RESC612
- ★ Built-in battery test modes
- ★ Suitable for cars with Start/Stop system
- ★ 7 stages of charging
The automatic model of an intelligent charger is designed for batteries up to 300 Ah. Provides for the possibility of repair work of the battery to improve its performance.
To monitor the status of the battery and the generator, equipped with the following functions:
• Battery Voltage: Displays a parameter in percent.
• Starting power test: necessary for timely identification of possible battery problems.
• Check the generator for the ability to charge.
• Having a cold start.
The LCD displays all the necessary information about the charging process.
- + function "test battery and generator";
- + 7 stages of charging;
- + BP mode;
- + Fully automatic charging process;
- + Ideal for vehicles with the Start-Stop system;
- + IP65 protection.
- - No storage bags.
Smart Charger CTEK MXS 5.0
- ★ Designed for lead-acid batteries
- ★ 8 stages of charging
- ★ The function of desulfation
- ★ Generator test function
The intelligent charger is designed to charge batteries with capacities from 1.2 A/h to 110 A/h. Provides automatic desulfation and reduction mode, which will bring into operation a fully discharged battery.
Equipped with test features to test:
• voltage;
• starting power;
• generator efficiency.
So, you get a complete picture of the operation of the charger and the state of the battery. It is equipped with special modes for charging in cold weather. There is protection against incorrect connection and short circuit.
- + Tests the battery and the generator;
- + 8-step charging process;
- + Full battery maintenance;
- - Wires are not flexible enough.
Intelligent Charger Ring RESC605
- ★ Rubberized case
- ★ Designed for batteries with a capacity of 2-160 A/h
4 PLACE
Automatic charger with comfortable control. So, with the help of LED indicators you can find out which charging mode is working. It can be used to charge all batteries, including helium, calcium.
Works in several stages, while automatically determining the most appropriate current for each. There is a special mode for winter charging.
- + Desulfation mode;
- + LED display;
- + 7-stage charging.
5 PLACE
Universal charger for charging 6 and 12 V batteries. Can be used not only for cars, but also for boats, snowmobiles and agricultural equipment. The model is equipped with a powerful microprocessor, which independently determines the state of the battery and delivers the desired current and voltage. Therefore, the charging process is as efficient as possible, no closures occur and the possibility of incorrectly adjusting the device is excluded-as a result, it lasts much longer.
The nine-step charge system includes both careful recovery and power. Provides a memory function, which is useful if you need to temporarily disconnect the battery. The device remembers the information at 12 o'clock.
Another advantage: the design automatically adjusts the voltage depending on the temperature. For example, in winter, this parameter will be higher, and in summer-lower. For beginners who have not previously encountered such devices, protection against improper connection and short circuit protection is provided.
- + Universal: for 6 and 12 V. battery;
- + Battery recovery;
- + Automatic voltage adjustment;
- + Multiple protection systems.
- - The absence of the "On / Off" button on the instrument itself.
Charging device — this design is almost essential. Their presence simplifies the life of the driver, because you do not need to constantly contact the car service center to charge the battery, especially if it’s freezing and the charge level drops faster. Having a built-in battery in the chargers will allow you to solve the problem of a discharged battery very quickly, for example, if you need to go to work. You can buy a smart charger in Kiev, Odessa, Kharkov with delivery in Ukraine at 130.com.ua.
Watch charger videos:
Materials on the topic
Starter-chargers: Best Sellers
