Choose a vacuum cleaner
Close
TOP 5 electric generators. Generator rating 2023!
Electric generators play a key role in providing electricity to various objects in the event of power outages. They can be used for a variety of purposes, including supporting the operation of shops, offices and even small businesses, as well as providing a comfortable life. The use of generators is especially important in country cottages or multi-storey buildings, where power outages can occur with a certain frequency.
However, choosing the right generator can be challenging as there are many different models available on the market. In such situations, it is useful to pay attention to the rating of the best electric generators. Our selection includes popular models from different price segments, which allows consumers to find the optimal solution, taking into account their budget and needs for home use or business.
We present to your attention the TOP 5 electric generators that are popular with our customers. Our rating is as follows:
Konner&Sohnen KSB 22i S
The first in our rating is the Konner&Sohnen KSB 22i S inverter generator with a built-in microprocessor. This type of generator has a number of features and benefits that make it an attractive choice.
This inverter generator is capable of generating stable voltage and current frequency, which avoids sine wave distortion. This is especially important for devices that are demanding on the quality of power supply. Can produce clean and stable electrical current that is close to what a regular electrical outlet provides. This makes the generator an ideal choice for use with sensitive electronic devices such as computers, televisions and others.
The microprocessor inside the Konner&Sohnen KSB 22i S plays an important role in maintaining the stability of the electrical output. It continuously monitors and regulates the generated voltage and frequency parameters, ensuring reliable operation of connected devices.
Among the characteristics and features of the model are the following:
  • Engine power: 2.7 hp.
  • Maximum output power: 2 kW.
  • Reliable gasoline engine with economical fuel consumption.
  • Universal control panel.
  • Alternator with copper winding.
  • Large fuel tank (4 l) ensures long battery life.
  • The possibility of parallel connection of generators is provided.
  • Compact and lightweight design with protective cover.
Konner&Sohnen KS 2000i S
The compact inverter generator Konner&Sohnen KS 2000i S is a modern solution for providing electricity to different consumers in different situations. This new model from the German brand Konner&Sohnen combines convenience and portability, making it an attractive power source for the home, office, construction site or countryside. The generator provides reliable power for a wide range of electrical appliances.
The basis for the operation of the Konner&Sohnen KS 2000i S gas generator is an inverter board with pulse width modulation. At full load, it can work up to 6 hours from one refill. In addition, its light weight and compact size make it easy to transport the generator and take it with you on outings. The generator is equipped with a handle for easy carrying and is housed in a noise-proof housing.
One of the key features of this generator is its ability to provide quality power to sensitive electronics due to the fact that it produces pure sine wave current. This makes it an ideal choice for connecting a variety of electrical devices, ensuring their reliable operation.
It is worth noting the following characteristics of the generator:
  • 2.6 HP engine, reliable and durable.
  • Economy mode reduces fuel consumption at part load.
  • The protective housing is dust and moisture resistant and has ventilation.
  • Simple control panel with sockets and indicators.
  • Overload protection and automatic oil level control.
  • Damping system reduces vibration.
  • Bottom high noise level during operation (56 dB).
Konner&Sohnen KS 4100i E G
The KS 4100iE G generator is an efficient source of electricity that is ideal as a backup power source. This model is capable of providing electricity to both a country house and a small store or even a production workshop.
An important feature of this generator is the built-in electronic unit with microprocessor control. This unit monitors the operation of the generator and guarantees a constant frequency of 50 Hz and a voltage of 230 V, which is important for the reliable operation of connected devices.
This generator has a universal dual-fuel system, which means it can run on both gas and gasoline. This allows the generator to adapt to the availability of different fuels on the market and provide reliable power even if one fuel becomes scarce.
Economy mode allows you to significantly reduce fuel consumption by up to 50% at low loads, thanks to lower engine speed. This is not only economical, but also reduces noise and wear on the generator.
Among the advantages of this model are the following:
  • Reliable branded K&S engine.
  • Maximum output power: 4 kW.
  • Low fuel consumption.
  • Convenient control panel with LED display.
  • High quality alternator with copper winding.
  • Possibility of parallel connection for increased power.
  • Convenient transportation with wheels and handle.
Hyundai HHY 9050FE
The Hyundai HHY 9050FE inverter generator is designed to perform various household and professional tasks. Can be used as a main or backup power source for a variety of electrical appliances.
It is equipped with a reliable 4-stroke gasoline engine from Hyundai, capable of providing continuous operation for 12 hours. The generator is easily started using the ignition key or manually. On the front panel there is a convenient control panel where the user can easily find all the necessary information about the current operating parameters. There are also AC and DC sockets for connecting consumers. This makes the unit extremely convenient and easy to use.
Features and advantages of this electric generator:
  • Reliable gasoline engine with 15 hp power. and long service life.
  • Maximum output power: 6.5 kW.
  • Electric and manual start.
  • Built-in oil sensor for automatic protection.
  • Stable voltage obtained using a synchronous alternator.
  • Durable steel frame for protection and stability.
  • High level of safety with insulation, grounding and protection against overheating and overvoltage. Automatic shutdown when necessary.
Hyundai HHY 1050Si
The Hyundai HHY 1050Si inverter generator is designed to provide independent power to single-phase electrical appliances. It operates with pure sine wave current and stable voltage, making it ideal for home use. You can, without fear, connect even complex sensitive electronics: computers, laptops, mobile phones and much more.
In addition, the generator has a low noise level, making it suitable for use in environments where quiet is important. For example, on hiking trips, hunting or fishing. Its compact dimensions make it extremely mobile, which makes it easy to transport and operate in various conditions.
Among the main characteristics and features of the model are the following:
  • Reliable IC 60 motor, EURO V compliant.
  • Maximum power - 1.2 kW, a reserve is provided for starting currents of powerful electric motors.
  • Manual start and easy starting.
  • Capacious 2.5-liter fuel tank provides long-lasting battery life up to 4 hours.
  • The generator has a noise-proof housing, it contributes to low noise levels and provides protection from moisture and dirt.
Related materials:
Generators: Best Sellers
