TOP 5 automotive compressors. Compressor rating 2023!
One of the key aspects affecting the safety of the driver and passengers on the road is the correct pressure in the car tires. And to maintain it, it is important to have a high-quality automobile compressor in your arsenal.
Nowadays, automobile compressors and pumps have become an integral part of the daily life of any motorist. They save you in difficult moments when a tire suddenly goes flat. With their help, you can very quickly and safely restore pressure and inflate tires, both in the garage and on the road.
In this article, we will provide you with an overview of the best car compressors available on the market. We will look at various models, taking into account their efficiency, reliability and functionality.
Our TOP 5 automotive compressors that are popular with our customers include:
- Compressor Hyundai HY 1765
- Compressor Berkut R20
- Compressor Sturmovik AS-50
- Compressor Ring RAC830
- Compressor Vitol K-72
Hyundai HY 1765
The Hyundai HY1765 auto compressor is a modern single-piston device designed to operate from a vehicle's 12-volt cigarette lighter. The model is characterized by high performance thanks to steel valves that can operate over a wide pressure range. PTFE seals provide resistance to wear and deformation.
With a capacity of 55 liters per minute, this compressor is capable of inflating an R15 tire in just 1-2 minutes. Its metal body provides reliable protection and can withstand pressures of more than 10 bar, and also guarantees a long service life, even with falls and impacts. And thanks to the built-in high-precision analog pressure gauge, you can easily monitor the current operating pressure.
To ensure comfortable use in the dark, the compressor is equipped with a bright LED flashlight. Please note that the device supports continuous operation for up to 40 minutes.
Berkut R20
This is a reliable and multifunctional device designed for effective inflation of passenger car tires. This model is a piston-type pump, and one of its main advantages is that the compressor does not require constant lubrication, which makes its maintenance extremely simple and convenient.
High-quality and reliable parts, such as a PTFE piston ring and stainless steel air valves, ensure high wear resistance and long service life. The working cylinder is made of aluminum alloy, which makes the device light and durable.
The electric motor is equipped with permanent magnets, which increases the efficiency of the automobile compressor. The built-in automatic overheat protection system ensures safety during operation. The compressor has a dust-proof design and a cleaning filter, which extends its service life and provides better tire inflation.
Accurate pressure measurement is ensured by a dual-scale pressure gauge, and the DEFLATOR valve makes it easy to reduce tire pressure. The device has a convenient bag for storage and carrying. The kit also includes a quick-release attachment for the wheel nipple for ease of use.
Shturmovik AS-50
The AS-50 Sturmovik is a reliable automotive piston compressor that represents an excellent combination of affordable price and high performance. The body is made of durable metal, which ensures its durability and ability to withstand heavy loads. The electric motor has copper winding, which increases its reliability and efficiency.
This compressor operates from a 12-volt car cigarette lighter socket. With a power cord of 2.7 meters and an air supply hose of 1.2 meters, it is quite convenient to use. An analog pressure gauge is installed on the compressor housing, which allows you to easily monitor the tire pressure level.
Maximum pressure - 10 Atm. Thanks to its high power of 170 W and a performance of 37 liters per minute, this car compressor is able to quickly inflate the tires of a car or SUV. For example, it will inflate an R15 wheel from 0 to 2 atmospheres in approximately 2 minutes 45 seconds. The continuous operation time at +23°C is 20 minutes, making it suitable for most tire inflation tasks on the road.
The kit comes with three adapters that allow you to inflate a variety of inflatable products such as boats, mattresses, balls and swimming pools, including o makes the compressor a multifunctional tool.
Ring RAC830
The Ring RAC830 car compressor is an indispensable accessory for owners of a wide variety of cars. With a maximum operating pressure of 10 atmospheres, it makes it easy to achieve the required tire pressure. Thanks to its high performance of 45-48 liters per minute, the compressor is able to quickly inflate the tires of not only a passenger car, but also a large SUV.
This compressor also comes with a built-in LED light, making it easy to use even in low light conditions. It also features a digital tire pressure gauge with LED display that provides precise monitoring of tire pressure to help the driver maintain it at the optimal level.
The package includes a long power cable 3 meters long and a durable hose 0.5 meters long, which provides sufficient flexibility and ease of use when inflating all four wheels. The body is made of high-quality plastic and metal, which ensures a long service life of the device. A comfortable rubber-coated handle guarantees a secure and comfortable grip; for convenient storage and carrying of the compressor, a branded fabric bag is also included.
Vitol K-72
This is a powerful device recommended for inflating wheels with a diameter of up to R16, but this compressor can also cope with larger tires without any problems.
The power of the two-piston electric motor reaches 350 W, which makes this compressor one of the most productive in its class. It can be powered either from the cigarette lighter or from the vehicle battery, providing flexibility in use. With a high output of 90 liters per minute, it is able to inflate tires quickly, which is especially important in situations where time is of the essence.
The compressor is equipped with a convenient pressure gauge located on the hose, which makes it easy to control the pressure. It supports two measurement systems - PSI and BAR.
The ergonomic design of the case includes a convenient carrying handle and rubberized feet for secure fixation of the device on the surface. The kit includes adapters for various accessories and inflatable items.
The air hose is 5 meters long, has a brass tip and a rubber pad, which ensures maximum comfort during use. The bag for storing and transporting the compressor is made of waterproof fabric.
Related materials:
Compressors and pumps: Best Sellers
