TOP-3 seat heating. Seat heating rating 2022
Most premium cars are often equipped with such a necessary and extremely important device in winter as seat heating. Without seat heating, it is difficult to imagine a comfortable ride in the cold season. But what about those who do not have heating installed from the factory? Today, a wide range of different types of car seat heating is presented on the auto electronics market. These can be heated wraps, covers, built-in seat heaters or even electric blankets.
All these types of seat heating differ in the way they are mounted and installed. Before buying, it is important to decide which type of heating is more preferable and whether you are ready to spend extra money on installation, since, for example, built-in models require qualified installation inside the seat.
Based on the demand of our customers, we have compiled a selection of some of the best seat heaters. Recommendations will help you make a choice that best suits your requirements and desires. Here is what our TOP 3 seat heaters look like:
Mitsumi M-1-K
This heating is mounted under the upholstery of the seat, regardless of the material of the seat, in the back and lower part. The power for the heating elements is taken from the on-board network of the car. The kits are completed with special wiring with all devices for protection against short circuit and overheating. The entire model line of Mitsumi seat heaters is identical in terms of performance and reliability, the difference lies only in the device control button.
The buttons of the kits can be either one mode (turning the heating on and off), or with a pair of modes (modes of the heating intensity of the element). The operation of all sets is the same: first, the element in the back and bottom is heated to 35-40 °C, and then the temperature of the selected heating intensity mode is maintained. The heating elements are made of carbon fiber with built-in overheating sensors to prevent short circuits and overheating.
HEYNER WarmComfort Speed 504000
Heated seat cover HEYNER WarmComfort Speed 504000 provides safe and fast heating with NC/AL heating technology. The very large heating surface creates even heat. The cape is equipped with an automatic shutdown system when the temperature reaches 65°C. The cape is very easy to use: it is connected to the cigarette lighter and has a cable length of 140 cm. The temperature is regulated by a three-stage model. The width of the cape is 44 cm, the total length of the cape is 91 cm, the height of the back is 50 cm, the length of the lower part is 41 cm.
Heyner 504000 features:
- Fix Wire Safety Heating
- Built-in thermostat to protect against overheating
- Built-in fuse-short circuit protection
- Quick install-secure mounting
- Suitable for all seat sizes
- Low power consumption (about 42W)
- Cable length approx. 140 cm
Elegant EL 100 600
Due to its versatility, this model is ideal for the interior of any vehicle. The ergonomic shape is made of high quality materials, characterized by excellent density values. The main advantages of using heating include: quick connection, efficient operation, reliable and fast fixation.
The universal cape plugs into a 12V powered cigarette lighter socket. Heating does not cause problems when turned on and is easily regulated thanks to an understandable heating temperature control system. The accessory is equipped with 2 levels of heat regulation. As a result of the quick heating of the seat cover, the driver and passengers will feel comfortable and cozy in the car.
Reliable fixation on the seat of the car seat is provided by a system of special fasteners that will firmly hold the cover while the car is moving. Additionally, to enhance the level of security, the mechanism has a built-in thermostat, which protects the cape from the risk of overheating.
Related content:
Seat warmers: Best Sellers
