TOP-3 car alarms. Rating of car alarms 2022
Now it is difficult to imagine any car without a car alarm. After all, it will help not only protect the car from theft, but also warn the driver in time about the approach of an outsider to the car. Modern security systems have enormous capabilities with a high level of protection. There are alarms with one-way or two-way communication, with GSM and/or GPS modules.
Manufacturers have also developed original technologies to protect their products from attempts to scan and code-grabbing. Therefore, when choosing an alarm, you should pay attention to the presence of an interactive or dynamic method of protection against scanning. Other interesting features worth noting are automatic start, Bluetooth, CAN and/or LIN interfaces, car search in the parking lot, and many others.
In order to choose a suitable alarm system from a huge number of different models, we have selected the TOP 3 car alarms that are most popular among our customers. This TOP includes:
Pandora DXL 4710
Pandora DXL 4710 is the most modern version of the security complex, which is designed to be installed on most cars. A reliable anti-theft system is able to effectively perform not only security functions, but also provide the car owner with service information and various opportunities. The main feature of the car alarm is the provision of high-quality communication of the security and service module in any location of the car. Mastering all the functions of the security complex will not take much time for both a professional master and an ordinary user.
This time, Pandora tried to improve its product as much as possible and take into account all the successful developments in previous models and apply new innovative technologies. A 4G modem is installed in the DXL-4710 car alarm housing, which not only processes data quickly, but also consumes a minimum amount of energy. Communication type: two-way supported GSM and Bluetooth.
When connected to a 2G, 3G, 4G network, all information regarding the vehicle (vehicle coordinates, status, alarm and service events) will be transmitted to the owner's mobile phone.
Among the advantages of the product are:
- A unique chipset created by the authors of modern BLE protocols-NORDIC.
- Car alarm support for any protocol and all the features of Bluetooth 5.0. And this is not just about compatibility (as is the case with some other car alarms), but about the original encryption system based on the full-fledged Bluetooth 5.0 protocol.
- Innovative modem antenna allows you to keep in touch in any conditions.
- Use to determine the coordinates not only of the GPS system, but also from other navigation groups of satellites. This allows you to find the vehicle anywhere.
- The ability to quickly control the system using mobile applications.
- The ability to control the preheater.
- Pandora car alarm operation with digital buses (CAN/LIN).
- Siren included.
- Having an anti-theft RFID tag can provide more protection for your vehicle.
- Control the system with a smartphone via 2G, 3G, 4G networks or Bluetooth 4.0-5.0.
Complete set:
- Control unit
- Owner Card
- Label (2 pcs)
- Handle for RFID tag
- Remote button
- Cable and hardware kit
- Beeper
- Relay module
- Temperature sensor
- Siren
- Connection diagram
daVINCI PHI-330 PRO
DaVINCI PHI-330 Pro is a two-way alarm without auto start. It provides the owner with such standard functions as passive and silent arming, anti-robbery mode, two-stage disarming, search for a car in a parking lot. It also allows you to implement separate opening of the driver's and passenger doors (the so-called "American type" central locking), support for engine operation (turbo timer).
There are outputs for 3 additional channels (connection of power windows or their control module, trunk lock, polite lighting) and two engine blocking. The central locking control module is a power one, which eliminates the need for additional relays. It is possible to connect an additional sensor, such as a microwave (so-called volume sensor).
The main key fob is equipped with an informative LCD screen and operates with a conversational code at a frequency of 868 MHz, which is characterized by increased resistance to hacking.
Complete set:
- Control module
- Two-way transceiver antenna with keyfob call function with LED status indicator
- 5-button keychain
- LCD transmitter with feedback function
- 4-button transmitter with rolling code
- Dual zone shock sensor
- Valet pushbutton switch
- Interlock relay
- Operating and installation instructions
Pandora DX 91 LoRa v.3
This is a two-way security and service system with integrated 2xCAN, LIN interfaces, a special port for algorithmic bypass of the built-in immobilizers of most modern IMMO/KEY cars, an integrated Bluetooth 5.0 interface (4.0-4.2 compatible) for communication with the owner’s smartphone, presence tags, and an extensive set of Pandora BT-peripheral expansion modules, and a built-in radio channel module operating in the 868MHz band with LoRa modulation.
Pandora DX 91 LoRa v.3 is an updated version of a popular product that differs from its closest analogues (Pandora DX-91LoRa v.2 and DX-90LoRa) by an updated Bluetooth 5.0 interface, both in software and hardware.
Instead of the Bluetooth transceiver NRF52832, the base unit is equipped with a new generation transceiver NRF52840, which is more powerful in hardware for transmitting, more sensitive in receiving, and has hardware error control for packet data transmission.
These features made it possible to increase the range of Bluetooth communication with modern mobile phones (with real BT 5.0 support) by several times. Depending on the nuances of the location of the car alarm base unit in the car, now the communication range with the Pandora BT mobile application can be from 50 to 180 m! It's comfortable and modern! After all, more and more people configure the parameters of security systems without GSM-connection using mobile applications. You can now easily and habitually set up an autorun schedule, change the sensitivity of sensors, view the history of events on your smartphone, without having to specially approach the car. It is quite enough to get closer to the window of an apartment in a multi-storey building, from which a car can be seen, and now it is almost always in touch!
Combined with the beautiful and very long range D-022 LoRa keyfob, full Bluetooth 5.0 makes this product arguably the best modern two-way car alarm on the market, for those who don't want to pay for a rarely used GSM connection, cost which rises in price again.
Complete set:
- DX92 Main Unit
- LCD Keyfob D022 DX 91 LoRa
- Keychain BT-760 black
- BTR-101 Radio Relay
- Spare parts for fasteners DX
- BS2 button
- DX90 v2 IMMO cable
- TM DeLuxe key cable
- c USB/micro USB cable
- X1000 main cable
- Immobilizer speaker
- Autostart relay module RMD-5M
- Analog temperature sensor cable L3000
- Piezoelectric Siren Pandora PS-330 (Р)
- Printed products
- Packaging
Related content:
Car alarms: Best Sellers
