TOP-3 car acoustics. Car audio rating 2022
Acoustics helps to create a good mood on the road, especially on long trips along the highway. After all, you must admit that traveling with your favorite music is always more fun. You should choose acoustics depending on your preferences. For some drivers, just background sound is enough, while others want high-quality bass.
There are component and coaxial types of acoustics.
The component system creates surround sound quality. It consists of several speakers to reproduce sounds in certain frequency ranges. That is, with this acoustics, you can place the woofer, midrange and tweeter in different places to improve the sound quality.
The coaxial system is more compact, easy to install and affordable. In this acoustics, all sound outputs are located in one speaker. The sound is obtained with mixed frequencies, and not as clear as in the component.
When choosing acoustics, you should pay attention to its size, as well as the dimensions of regular seats in your car. Acoustics are small sizes up to 13 cm, medium-15-18 cm and large more than 20 cm.
You need a sound amplifier to drive the speakers. Whether external or built into the head unit. The higher the sensitivity of the speakers, the less powerful the amplifier is needed.
Let's look at the TOP 3 popular car acoustics among our customers. Our rating looks like this:
Focal Auditor RSE-165
The FOCAL RSE-165 component car speaker is an excellent choice for lovers of high-quality sound. It combines excellent performance, high performance and easy installation.
Among the advantages of this two-way kit, we can distinguish high power (60 W nominal, 120 W peak) and sensitivity (91.5 dB), which allows you to make the sound as rich and realistic as possible, revealing all the capabilities of the installed head unit. The operating frequency range is from 60 to 21000 Hz.
The main speaker (woofer) received a polypropylene cone with a matte finish on the front side, which is a bit like soft-touch material. The material is light but quite durable. The sound is smooth and fairly clear, without distortion and extraneous noise.
The woofer received a solid stamped steel basket and a medium-sized magnet (86 mm). The centering washer is quite large, it allows to achieve an increase in the linearity of the diffuser movement within the usual limits. This also contributes to a cleaner and smoother sound. The installation depth is 66.5 mm.
The tweeter features a proprietary reverse-dome design that reduces the effect of sound angle. The dome is made of majolar, a material that combines very low mass, minimal directivity and excellent sound linearity. Installation is possible both recessed and on the surface.
Crossovers are small in size and weight, made in a durable plastic case. Due to their compactness, crossovers are very easy to install, as there will be no problems finding a place for installation.
The kit includes the famous inverted dome tweeters, which can be easily installed in regular places; main speakers with a diameter of 165 mm and crossovers. Also included is a flat-shaped protective grille and mesh for maximum sound dispersion.
Hertz DSK 165.3
Hertz DSK 165.3 is an acoustic system developed by Italian experts using the latest technology and meeting the highest quality standards. This equipment is able to replace the regular car acoustics without the need for additional interior preparation. Its distinguishing feature among similar products is deep, bright and loud sound reproduction even when combined with a low power head unit.
If we evaluate the technical parameters of the Hertz DSK 165.3 2-Way system, then first of all it is worth noting the thoughtfulness and accuracy of the design. The manufacturer strictly monitors the quality of the equipment produced, so there is no doubt about its high level. To fairly evaluate the capabilities and qualities of the Hertz DSK 165.3 2-Way system, you can familiarize yourself with the list of its parameters:
  • Type-two-way component acoustics;
  • Power consumption of electricity-80 W;
  • Size 16.5 cm;
  • woofer/midrange driver with waterproof compressed cellulose cone and ferrite magnet;
  • Tweeter with PEI cone and neodymium magnet;
  • Voice coil on Kapton frame;
  • Supplied with a mini crossover HPF, 3.5 kHz, 12 dB/oct;
  • Installation depth 64 mm.
Key features of acoustics:
  • High sensitivity (93dB/2.83V/m);
  • Wide frequency range, including performance from 50 to 23000 Hz;
  • Balanced loud sound with deep bass;
  • Compact tweeters for easy installation;
  • Included with the device are mounting accessories, including mini podiums;
  • Small size flange;
  • The ability to work smoothly even under extreme temperature conditions;
  • Protect against mechanical damage with a rubber speaker dome and heavy-duty basket shell.
The Hertz DSK 165.3 is the perfect choice if you want a balanced, bright sound with the lowest hardware investment. Despite the affordable cost, the system in question has excellent technical characteristics and can work directly from the head unit as a substitute for standard acoustic equipment.
Pioneer TS-A1600C
This is a 2-way component speaker system from Pioneer. High-quality materials allow you to improve the reproduction of low and high frequencies. The concept of creating acoustics Open&Smooth, gives excellent technical characteristics, which will allow you to get incredible sound. Even at high volume levels, this model reproduces deep bass and natural sound at high frequencies. Suitable for replacing the original speaker system and is placed in the regular places of the car. A special multifunctional adapter (Custom Fit Adapter) will serve to improve acoustic performance, quick and easy installation.
The speaker has a long-term RMS power rating of 80W and a maximum advertised power of 350W. Frequency range from 34 to 49,000 Hz. Sensitivity level 85 dB. The nominal impedance is 4 ohms, this must be taken into account when matching the amplifier and speaker load.
The woofer basket is stamped steel, has a round shape with a standard size of 6.5 inches, it is 165 mm, and is resistant to resonance. When installing, pay attention to the installation depth and installation diameter, which is 144 mm. The speaker cone is made of seamless composite IMPP material, black, it is a light and rigid material, with good internal attenuation, which allows you to transmit music without distortion. It is suspended and centered by a wide black suspension. Speaker with copper voice coil and Y35 ferrite magnet, high density.
The tweeter is 30 mm in size, made of polyethylene terephthalate (PET), it is a durable and fairly light material, with a small size neodymium magnet.
The kit includes 2 woofers, 2 tweeters, necessary fasteners, user manual.
Related content:
Car acoustics: Best Sellers
