Features of operation and safety when using starter-chargers
For uninterrupted and full-fledged car operation, a sufficient amount of gasoline is required in the tank, and also the availability of a serviceable and fully charged battery. A if it is suddenly discharged, then a starting-charger can help solve this problem.
This device is a very complex mechanism that requires special attention and caution during time of its use. Before using the charger, you must first study the instructions for its use and safety regulations. In this way, you will be able to protect yourself from unforeseen and unpleasant situations resulting from the use of equipment.
What do we take into account when using starter-chargers
Every driver should remember that these devices should be used only in specially designed places with an increased level of ventilation. This is a very important point that all drivers need to know.
The need for using starter chargers is obvious. Such a device though would have used many drivers. For the selection of the optimal option of the ROM, you should familiarize yourself with the proposed models of devices presented at us on the website. you can buy starting-charging devices with delivery to Kharkiv, Kiev, Odessa and all over Ukraine to & nbsp ; 130.com.ua.
There are a huge number of types and device models on the battery charging equipment market. They differ not only in brand and size, but in and performance, parameters and some functionality. In general starting and charging devices are divided into three types:
1. Professional;
2. Household;
3. Combined.
Depending on the type of device, you need to adhere to a number of important rules that will make using a starter charger safe and simple.
Features of operation of each type of devices
Combined models are a combination of ROM with a welding machine. In this case, the use of the second type of equipment is possible with a voltage of 40V, not less, and here is the starting and charging device-only 12V. During ROM operation time, a special toggle switch must be switched over to the output indicator required for recharging. The danger of using these devices is the possibility, for whatever reason, to forget about switching from “welding” to “ROM” mode, which may cause a breakdown in your car’s wiring, or, in extreme cases, a fire will occur.
Using other starting and charging devices, it is necessary to take into account the presence of protective mechanisms from:
- wrong polarity;
- short circuit;
- spontaneous combustion;
- overvoltage.
It is very important to have regulatory functions with which you can stabilize the current level of the charger. Equipping the system with the normalization of the supply voltage is not less necessary, especially during time of poor stability of the supply voltage in the power supply network.
Safety when using ROMs
During the operation of start-up chargers, it is not necessary to forget about such an important factor as safety measures. Before using this device, you need to consider the rules regarding the use of ROM.
1. After purchasing a starting charger, you should carefully read the instructions.
2. It is forbidden to combine the clips in black and red, this can lead to subsequent malfunction of the battery or ROM.
3. When charging a battery of acid-lead type, you need to wear special elements for protection-rubber gloves, goggles, and also nonslip shoes on a rubber sole.
4. The room where the charge will take place must be well ventilated.
5. It is forbidden to include a ROM on street during rainy weather.
6. It is not recommended to make an independent repair of the device, as there may be more significant faults. In these cases, you need to contact only specialists.
7. Before charging, it is necessary to clean the battery terminal from oxide and mud residues, this improves the contact of devices, and eliminates the likelihood of a short circuit.
8. It is not recommended to leave the start-up charger on a long period without your supervision, especially during charging time on the auto board. Voltage disruptions may occur, resulting in possible battery failure or malfunction of the vehicle’s electrical system.
By following these guidelines, you can quickly and recharge the battery successfully. As a result, your car will be back in working condition for a long time.
Materials on the topic
Starter-chargers: Best Sellers
