Causes of dim headlights
Poor illumination of auto optics is an actual problem for many car owners. And its reason is that the market has a lot of fakes of poor quality, as well as the innovations of the rules of traffic rules, which require the inclusion of dazzle even during the day. Hence-increased optics, frequent breakdowns and dim light.
In case of faults, you can replace parts or even buy new devices. But to solve the problem of poor lighting will be much more difficult. First you need to determine the cause of the problem.
Often the lights dim due to the wear of the spotlight. In older car models, such a malfunction appears on long journeys, since the upper surface of the spirals becomes cloudy. In the end, the spots absorb light beams.
We now turn to the electrics of the car. Determining how to deal with such a cause requires special knowledge. If you do not have those, then without hesitation go to the service station. Sometimes "I will only try" can only aggravate the problem.
There are cases when the reason lies in the banal fogging of the headlights. Here we get this situation: the light is refracted by condensate and therefore the level of illumination is reduced.
Another headlight may be covered with a thick layer of dust. The reason is already in the cleanliness of the car owner. We recommend in this case more often go to the car wash or wipe the optics on your own.
Pay attention to the diode element in the headlamp. If the tightness of the lamp leaves much to be desired, third-party elements can get inside the structure and lead to malfunctions. In practice, the driver complains about the sharp change in the work of lighting devices. The most common cause is the manufacturing defect of the lamp itself or the harsh operating conditions of the car.
It is also important to check the integrity of the optical diffuser. Cracks and scratches may occur during headlight cleaning. Therefore, do not forget about useful advice-do not wipe the reflector until it dries.
To pinpoint the cause, use a very simple and proven method. Take off the glass surface of the headlamp, look at it through the light. If the outgoing flow level is more than normal, then proceed to check for another reason. And if you notice dullness-engage in grinding the surface or replacing the glass itself.
The problem of dim light should not be postponed until later, because muddy headlights can cause an accident. Just follow simple preventive measures and thus protect yourself from emergency situations.
Related Content:
