Compressor for cars in the complete set
A flat tire, a puncture on the road, an unloaded “reserve”... Which driver has not encountered such troubles? And how important is regular tire pressure monitoring and its correct level? How easy it is to solve such problems knows every motorist who has a compressor in the trunk. This necessary tool in every car will be doubly useful if you are still a fisherman or an active leisure enthusiast. After all, with a compressor, pump up an inflatable boat, mattress, ball, cycle tires, etc.-minute business. How else would such a pump be beneficial to the owner and what can be found in a modern compressor, in addition to the compressor?
The pressure gauge makes the pump more user-friendly. Providing accurate pumping and reporting of pressure level, analog or digital, a pressure gauge is a valuable addition. The device can be removable/non-removable, mounted on the body, air hose, have a removable/non-removable protective cover. High accuracy, minimal error, no vibration during inflation make digital gauges more attractive than mechanical ones. And their clear display on the LCD screen with LED backlighting will provide the necessary information, visual even in the dark.
If you buy a car compressor with the AutoStop function ”He will turn pumping up into a simplest occupation that does not require the constant presence of the driver. The device will automatically turn off when it reaches the air pressure of the specified level. The automatic overheating protection system provides for shutting down the compressor when the permissible temperature of the case is exceeded (important for long-term operation). The built-in thermal sensor will prevent damage to the device from overheating.
Built-in flashlight-find for use in the dark and in low light. The choice of color, intensity and light mode allows the use of compressors with such a universal lamp for additional lighting and for emergency signaling in emergency situations. A set of adapters and adapters, including a nozzle for air descent, significantly expand the functionality of the pumps. They can be used to inflate/blow off tires of various kinds, various inflatable equipment. Also useful for inflating/lowering tires, to easily customize the car for individual driving style and specific road conditions. The moisture-proof case of the compressor creates additional convenience and allows its use in various weather conditions.
In the catalog 130.com.ua you can choose a multifunctional modern compressor, the price of which, as a rule, includes a capacious set. A spacious waterproof bag-case or a plastic case with different compartments, pockets allow ergonomically store/carry the car compressor and all the complete accessories, and always have them at hand. Order and buy such a necessary accessory in our online store to always be ready for convenient self-service cars and easily cope with malfunctions on the road. you can buy a compressor in Kiev, Kharkov, Odessa at 130.com.ua with delivery in Ukraine.
Materials on the topic
Compressors and pumps: Best Sellers
