Which car compressor is better to choose?
A car compressor is one of the main accessories for drivers, because the need for tire inflation may arise for everyone, and at the most inappropriate moment: where there is no car service station nearby. Pumps are an equally effective way to solve problems, but they take more physical effort and time.
Compressors have great performance, are also equipped with additional functionality, markedly increasing the comfort of use. Moreover, such devices can be used for other objects, for example, for boats or bicycles.
Design features of compressors
Today you can meet two types of such devices: piston and membrane. Each species has its advantages and features.
Piston-a piston is used as an element for air compression, which starts working at the expense of an electric motor. Here it is important to take into account the quality of each individual part, and the rod itself must be made of alloy steel.
Among the main advantages can be identified high levels of power and performance accordingly. Piston autocompressors can be used for tires with pressure up to 8 atmospheres.
Membrane differ in simpler construction. The main element is a membrane made of durable material, which is operated by an electric drive. Models of this type are more reliable, but do not provide for the development of high pressure. Membrane compressors are ideal for cars.
What to look for?
Among the wide range of autocompressors, it is difficult for a beginner to choose a suitable model. Often, buyers have only two requirements for the device-high performance and long service life. Consider the following when selecting:
Maximum pressure. In theory, 2-3 atmospheres are enough for the simplest car, but in practice it is better to choose a design with the ability to produce 7-10 atmospheres.
Performance-the time it takes your tire to pump. Everything is simple: the higher this parameter, the greater the price. If you buy even the most budget model, it will take you up to 10 minutes.
These two parameters are the most important and basic. Now consider the characteristics that affect the comfort of using the device:
Connection method-through the cigarette lighter or directly to the battery. The first option is considered more convenient and reliable, while the second is designed to connect powerful structures that can disrupt the cigarette lighter. Having a battery also saves you from having to take care that the design may not reach the rear wheels.
The length of the cord-you should calmly reach all the wheels of the car. If you have a passenger car, then in principle there should be no problems. Especially if the model has a battery, then you will not have to think about this parameter. For truck owners, it is important to consider the length of the cord: on average it should be 5 m.
The presence of a flashlight will make use of the compressor at night more comfortable. And additional adapters will expand the scope of application of devices: boats, mattresses, balls, bicycles.
The gauge shows the pressure value. This element can be analog and digital. In the first case, it is best to choose devices in increments of 0.1 atm. The second option is more reliable and able to show more accurate data.
Some models of automotive compressors are equipped with an auto stop function: the air supply stops as soon as the pressure parameter reaches the desired values. A special bag will improve the storage conditions of structures.
3 best models of 2017: review
Among the wide range of catalog autocompressors, it is recommended to pay attention to the following models.
Berkut R15-popularity is largely determined by the very small dimensions of the model: it weighs only 2 kg. Performance parameters reach 40 liters per minute. A special extension cord is provided for the wire, which increases the comfort of using the design for trucks and large cars. Equipped with additional nozzles. The maximum pressure is 10 atmospheres.
Berkut R14-has a minimal level of vibration. Provides good performance parameters: 40 liters per minute. The presence of overheating protection system eliminates the possibility of disrupting the performance of the cigarette lighter. The two-scale manometer is intended for display of the most exact indicators. LED flashlight makes use of the compressor comfortable even at night. The model is designed for wheels with a radius of no more than 14 inches.
Vitol KA-T12181 Tornado is a budget version of compressors with the simplest design. Perfectly copes with the main task-air supply to the tires. The maximum pressure parameter is 10 atm, while the model is no less productive-as much as 35 liters per minute. The device is equipped with an LED flashlight and storage bag.
When choosing, keep in mind that membrane models cannot be used in frost. Pay attention to the performance and maximum pressure of the compressors. you can buy an autocompressor on 130.com.ua with delivery to Kharkov, Odessa, Kiev and in Ukraine.
Related Materials
Compressors and pumps: Best Sellers
