How to choose brushcutters?
Trimmers is a versatile tool that will be useful on the farm. You can use it to mow tall grass, prepare livestock feed, maintain the lawn near the house in a neat form, etc. This is a pretty powerful tool that is able to cope even with strong bushes. The basis of operation is brush cutters gasoline engine (2- or 4-stroke) rotates, it imparts kinetic energy to a cutting tool system as it may be mono filament, disc or blade.
This tool will be a great companion for any summer resident or holiday homeowner. However, it is very important to choose the right model so that it can cope with the work and the load. To do this, it is important to know the technical parameters that affect the efficiency and ease of use brush cutters.
Basic technical characteristics and particular gasoline mowers
The amount of the proposed models in the stores is very large, and they are all with each other can vary in a number of indicators. Let's look at the most important ones that will help you make the right choice.
Engine Type
The engine-the most important element of a design. From it depends primarily on the performance of the tool and its life.
As we have noted previously, the motor can be of two types:
- Two-stroke — the design of this engine suggests that the piston makes the 2 moves per cycle. For their work using a fuel mixture of petrol and oil, which should be mixed in the proportions specified by the device manufacturer.
- The four — in which the piston makes 4 turns per cycle. Gasoline engine oil enters the combustion chamber separately.
Motor type
Benefits
Disadvantages
2-stroke
- The small size and weight of the device.
- A more economical, compared to 4-stroke models.
- Do not require additional lubrication, as the oil in the engine comes already from the finished mixture.
- Their service life is 2 times less than that of the 4-stroke.
- An unpleasant burning smell and smoke can be observed in the combustion mixture.
- A mixture of only fresh, ready to store for a long time can not be possible to use.
4-stroke
- A more powerful as compared to 2-tatnymi as ceteris paribus have great momentum.
- Work longer because there is less prone to friction and mechanical wear.
- A more quiet in operation.
- Have little or no odor at work.
- The higher the price.
- It is necessary to monitor the level of oil, which is poured into a special housing.
- The heavier and overall, compared to 2-stroke.
Engine power
This setting affects the speed and width of mowing, and the type of vegetation, which would be able to operate this mower. All devices can be divided into 3 type:
- Home (up to 1kW)-their use is recommended for occasional cutting low grass and weeds in small areas, for example, on the front lawn. With a heavy load such a device can not cope.
- Universal (from 1 to 3 kW)-these models are already suitable for intensive cutting grass on the medium area of the territory, in parks and gardens.
- Professional (from 3 kW and above)-are suitable for continuous operation, this brush cutter is easy to cope with cleaning large areas of grass. With the help of these tools can also be hay, cut shrubs or growth of young trees.
The number of revolutions of the cutting system
Here it is necessary to take into account that the speed of rotation will be different when using a fishing line and a knife. This is due to the fact that the blades and discs are made mostly of metal, it increases the load on the engine at a set rate. Therefore, when using knives rarely maximum rotational speed exceeds the index of 7000 rev/min. At the cutting head and line main rotating elements usually made of plastic and have a smaller footprint. This allows them to spin faster in such petrol queues grass peak speed can reach the level of 10,000 rev/min and more.
Type of cutting system
Cut the grass in mowers are different cutting elements: woods, metal or plastic knives.
The line
This type is only designed for cutting small and young grass. Monofilament (nylon cord) may be of several types:
- No reinforcement — it is quite strong and wear-resistant material, which is suitable for cutting fresh grass.
- Reinforced — a feature that is within a more dense material, such as metal. This line was more rigid and very strong, able to withstand high loads. It is used only in high-end models.
In addition to the type, it is necessary to choose the right fishing line thickness (diameter). If it is very thick, it will increase the load on the engine, thereby reducing the number of revolutions. As a general rule, the manufacturer specifies the recommended diameter of the fishing line in the device user's guide.
You can also navigate to the following recommendations:
- 1,6-2 mm — This line is suitable for low-power devices with an engine capacity of up to 750-800 W;
- 2,4 mm — the most common size, which is suitable for most consumer devices;
- 2,7 mm — recommended for semi-professional tools;
- 3 and 3.3 mm — diameter of the monofilament is intended for professional brush cutters.
Usually monofilament is used in low-power model where the engine can not maintain a high metal blade speed. Due to lack of power in a knife device will slip, brake and stick in the grass.
Knives
They can solve more complex problems and can easily cope with the thick, old grass and shrubs and shoots of young trees.
Knives come in several types of form and function:
- 2-tooth-they can be used to mow the young grass;
- 3-tooth-excellent job with a tough grass and weeds;
- 4 toothbrushes-are designed for cutting in dense thickets;
- 8-tooth-their purpose-Hay;
- Metal wheels-used when it is necessary to cut the bushes or woody growth.
Please note that the knives are also distinguished on the outside diameter. This should be considered when buying a knife should be suited to your model mowers.
It is also worth noting that there are some models that are used simultaneously both cutting system: the fishing line, and a knife. As a rule, it is a powerful and high-performance devices.
The shape of the bar
On the working properties of the instrument also affects the shape of the handle:
- The curved bar — this usually have a low-power models that are used for cutting the line. They are intended for occasional mowing the lawn, for the treatment of small lawns, removing the grass under the benches, the trees, etc. It is important that the grass was soft and young, without a lot of weeds.
- Direct bar — it usually has powerful and versatile model. Inside this handle is not used a thin rope, a sturdy tree, this brushcutter can work with any cutting elements and can tolerate high loads.
Brush cutters Weight
The weight of the device depends on various factors: the design features of the materials used and of course, the engine power. The most powerful model will be the most difficult. It is important to find a balance, as a heavy instrument to work harder than easy, but take the smallest is not always rational, so the petrol scythe grass can not cope with the task.
There are several weight categories:
- From 4 to 5 kg-a compact model with a fishing line, used for mowing grass shallow. They are ideal for the care of a small lawn at the local area. With such a tool handle and a woman and a teenager and senior citizen.
- From 5 to 6 kg-this includes most consumer models with good power, such devices operate with metal blades and discs suitable for use in dense thickets.
- From 7 to 8 kg-this is a professional device with a steel rod and forged one-piece shaft, designed for difficult mowing large areas where you need a high capacity drive. With this tool has to work a strong man, for domestic purposes are seldom used. Home and garden recommended buying something easier.
Advanced Settings
When choosing a petrol scythe, we must not forget about other options that are also important and affect the operation and effectiveness of the device:
- The width of the cutting — a site that can mow down the device in a single pass. The best is the value-225-300 mm.
- The capacity of the fuel tank — for the garden and a small garden brush cutters fit with the tank from 0.3 liters. For more complex tasks that require a more continuous operation, for example, hay recommended model tank 1.2 l.
- Height adjustment knob — this is a very useful option that allows you to adjust the bar and lead it as comfortably as possible for the operator.
- The presence of the shoulder strap — this increases comfort during work, because they do not have all the time to keep the weight on the tool. Belt helps distribute the load evenly.
- Adjust the length of fishing line — With this function fishing line each time the engine is started automatically appears. There are also brush cutters with semi-automatic adjustment system, when it is necessary to press a special button on the reel to a new fishing line.
If you want to buy brush cutters in Kiev, Kharkov and Odessa, the online store you 130.com.ua will find a large assortment of models, as well as other garden tools at a reasonable price.
Related materials
Lawnmowers, trimmers and brushcutters: Best Sellers
