How to choose a tire booster compressor?
At least once every driver met with the need for tire inflation. It is good if this happened not far from the car service center, but what if on the road where there are no gas stations or tire fittings near? In such cases, the automobile compressor is a lifeline that will help solve the problem quickly.
A pump can still be used, but it is harder to operate and requires more effort from the car owner. In addition, modern compressor models have a number of important functions that significantly increase the comfort of using the device.
Types of compressors
Due to the widespread popularity of autocompressors, they are usually divided into two categories:
Piston compressor. The functioning of such devices is due to the piston responsible for the inflow and outflow of pressure in the tires. A feature of this type of construction is high system performance and long service life. Please note that piston compressors for a car are very hot and have almost no air filtration.
Rotary piston: designed to supply a large amount of air.
Membrane: the operation of such devices is due to the rubber sheet, responsible for the inflow and outflow of air in the tires. The model range is also called vibration. The main advantage is the absence of small rubbing elements, which often break. Please note that such devices are difficult to cope with low temperatures and do not have high performance.
The choice of the type of compressor for the car depends on your preferences, goals and conditions of use of the structure.
Key Features to Consider When Choosing
If you are faced with the choice of a compressor for the first time, then you will surely get lost with such a large assortment. For a good purchase, take into account such characteristics:
Pressure. If you have a regular passenger car, you can even ignore this parameter, because even a model from the budget category will cope with its tasks with distinction. However, if you have a truck, then consider the value of a valid parameter: it should be 8-10 atm.
Performance. The most important indicator that affects the tire inflation rate. On average, the parameter is 25 liters per minute. Such values are enough to pump up the wheel R15 in just 2 minutes. Accordingly, the larger the wheel, the longer the pumping time.
Pressure gauge. Given the information from this device, you will be able to raise the pressure to the desired. In most cases, the device uses two types of pressure gauges: digital and analog. The first option is the most comfortable because it shows the data more accurately and is not affected by vibration.
Connection Type. Most compressor models have a classic power connector. More powerful designs can be equipped with crocodile clips, which are protected from overload on-board network.
The compressor can be equipped with various features and capabilities. For example, the option "autostop": in this case, the device turns itself off as soon as the tire pressure reaches the desired parameters.
If you often travel by car, then a practical option for fuel economy would be a bleed valve, which provides the ability to raise and lower pressure in the wheels. The presence of adapters allows you to use the compressor for other objects, for example, for a bicycle or an inflatable mattress.
Overview of popular autocompressors: features and benefits
Having decided on the important characteristics for the correct purchase of an autocompressor, you can proceed directly to the choice of model. Now let's take a look at popular models.
ELEGANT FORCE PLUS 100 043-a rotary-piston design in a metal case with 4 rubber legs and a cooling system. For comfortable operation of the device, a storage bag is provided.
Compressor capacity reaches 35 liters/minute. According to the manufacturer, the device can give a maximum pressure of 10 atmospheres. Provides autostop function and adapters for pumping other objects. The long power cord (2.7 m.) Allows you to comfortably use the compressor in large cars. An analog gauge shows information regarding tire pressure parameters.
HEYNER DIGIMATIC PRO 236-is a multifunctional design. In addition to the main task, this model also provides a flashlight with a special lining: you can use the compressor at night or as a signal light.
The digital pressure gauge accurately conveys all tire pressure information, and the auto-stop function makes it much easier to use the device. The maximum pressure reaches 7 atmospheres, the performance is equal to 27 liters per minute.
The VOIN VP-610 is a small-looking construction, distinguished by its power: capacity is 70 liters. per minute, and tire pressure-10 atmospheres. So, the compressor can be used for SUVs or trucks. The main distinctive feature was the power system: there is a direct connection to the car battery.
A long cord (5 m.) allows you to easily inflate tires even a long car. The case is equipped with dust and moisture protection properties. An analog pressure gauge is provided for displaying data.
RING RAC640 is a practical option for those who often like to go on holiday. The main feature was the presence of two pumps that solve different problems: for example, the scope of use of the compressor is significantly increased. Piston motor-for car tires, rotary-for mattresses, boats.
There is a “blowing off” function; for this purpose, a special switch is provided on the device case. An illuminated digital pressure gauge provides accurate tire pressure information even at night.
Choosing a compressor is an individual matter for each car owner. Even the most budget option will cope with the main task, and additional opportunities are your desire and possibilities. you can buy an automobile compressor in Kharkov, Odessa, Kiev with delivery in Ukraine at 130.com.ua.
Related materials
Compressors and pumps: Best Sellers
