How to choose a car compressor in 2020: the main parameters and features of modern devices
Inflating the tires-a process very responsible and important that the compressor has been easy to use and functional. Few people currently using hand pumps, it is long and requires greater effort, is much more convenient to take the electric compressor, which does everything quickly and efficiently, without the hassle. Let's look at what should be a modern compressor and on what parameters need to look at a choice in 2020?
What are the main performance indicators in the selection
It's all quite simple, first of all, look at the device data sheet and look at the two main indicators.
Performance
This option shows how many liters of air in this unit can be pumped per minute. To select the value of performance should be based on the brand of your car and tire size. Obviously, for small passenger cars big performance is required, such devices are expensive, but the special benefits you do not get just wasting your money. But the compressor is required to have a more powerful for an SUV or truck. For example, the need for SUV compressor with a capacity of 50 l/min, for wagon-not less than 70 l/min. But for an ordinary passenger car with enough apparatus will air volume of 30-40 l/min.
Maximum pressure
This indicator has a direct impact on the efficiency of the compressor is measured in atmospheres. The optimal domestic automobile compressor 8 is considered to be the pressure in atmospheres. This will be enough for high-quality and stable operation of the device. If the package is indicated 20-25 atmospheres pressure, it is very doubtful, as for simple models of portable compressors is unrealistic figure.
What else should look, if you decide to buy a car compressor
In addition to the main parameter that determines the efficiency of the device, if you have two important factors that affect the usability avtokompressora.
View gauge
When inflating tires is very important to be able to control the pressure, so the driver will know exactly about what the tire pressure it really get. For this purpose, a special device-a pressure gauge. This is a simple, but very important component that must be in every modern compressor. With it you can easily control the process and to determine the time that the tire is inflated and the pressure therein corresponds to that specified in the data sheet for your wheels. Remember that it is not desirable to exceed this value, it can hurt.
There are two types of gauges:
- mechanical (analog) — have an arrow and a special double numerical scale. One unit of measurement indicated western type-psi (pounds per square inch), and the second-the more usual our drivers bar (atmosphere or kilograms per square centimeter). Their peculiarity is that they have a certain error and the arrow is constantly shaking, which can make it difficult to define the level of pressure, especially the habit.
- Digital — this is a more modern version, they differ a great measuring comfort. Vibration does not stop here. This gauge typically has a display on which can be clearly seen the actual pressure level in the tire wherein they show results quite accurately, the value displayed in hundredths. Also, you need the units can be set in many cases.
The important point. Model of automobile compressors with electronic gauges are also often equipped with a function of "hitchhiking". That is, before the tire inflation pressure is enough to set the desired level for your wheels and turn the unit on. Most do not need to do anything, even the process does not have to control. Reaching the limit that was set, the unit itself will automatically stop the job and off. It is very convenient, since the driver can do other things, without fear that overinflated tires.
Catering
Of course, like any electronic device, the electric automobile compressors need food, they work on electric current. The road is often no electrical outlets, so all the compressors according to the process food are divided into 2 groups:
- Work from the vehicle on-board network There are also several possible options:. Devices that are connected via the cigarette lighter socket or to the battery by means of special cables with contacts such as "crocodiles". Some models are equipped with two types of power wires that allow you to connect them to the cigarette lighter, and a battery. This type of device is the most popular, such as the compressor is easy to take with you on the go and at any time with the help pump up the tire, even in the forest.
- have their own built-in rechargeable battery. As a rule, these models are more powerful, but it is a bit bulky and heavy, is not always convenient to carry them with him in the trunk, although in work, they are quite effective and productive . Typically, such compressors are recommended to take for trucks, which really requires a good performance and autonomy. Most importantly, if you choose this type of compressor, do not forget before the trip be sure to charge the device, so that later on the way it has always been ready to go.
Additional useful options
Before you buy a compressor for the car, do not be amiss to ask what additional features has this device. Among the most useful is to provide the following:
- The presence of the bleed valve. If the compressor is equipped with a similar element, then with his help, if necessary, can be very quickly lowered a little tire and wheel make softer. For example, it may be necessary if you have to go long for the simple dirt country road.
- air pumping. The convenience of this feature is that it allows you to quickly lower the various inflatable objects, such as a swimming pool or a boat.
- The "Hitchhiking" — pumping of tires to a predetermined pressure indicator with automatic shut-off (digital pressure gauge). On it we said earlier, a very useful feature, without which it is difficult to imagine a modern compressor.
- Protection against overheating. This feature requires automatic activation of a special thermal relay, which will not allow the unit to overheat, it promotes a long and safe operation of the compressor.
- Lantern. option is also quite useful on the road, the flashlight can shine in several different modes (illumination, emergency blinking).
- set of adapters. Some models of automobile compressors can additionally have a special nozzles, which allow to pump a variety of inflatable equipment, such as an adapter for boats needle for balls, etc.
- cover. If the product comes complete with a carrying case, it can be used for storage and easy transportation. Case also has a protective function, not allowing dirt to penetrate the unit, dust and moisture.
As you can see, everything is simple maximum. And when choosing a car compressor most important thing to determine in advance with its basic operating parameters, as well as a set of additional features that will be needed. So you can accurately find the best option and will not overpay for the options, which then will not be using. Buy compressor to inflate tires in Kiev, Kharkov and Odessa, you can always at a bargain price in 130.com.ua online store.
Related materials
Compressors and pumps: Best Sellers
