How to restore a discharged battery? Battery desulfation
The car battery over time discharges and loses inrush currents. During the launch of the battery with a gasoline engine, the battery is partially discharged and for its full recovery will have to travel more than 30 km. Only in this way can a battery recover energy. In the conditions of modern driving to achieve such conditions is simply impossible. It turns out that after each launch the battery is not fully charged. Therefore, salts are deposited on the plates and the process of sulfation begins.
Over time, the battery stops working. It will be possible to restore its functionality only thanks to special devices with the ability to desulfate the battery. So, sulfation is a problem, and desulfation is a solution.
How to extend battery life?
In most cases, we remember the battery when the first faults appear. And in vain. The battery also requires periodic maintenance, like any other vehicle mechanism.
So the first rule, if you want to extend the life of a battery, is to prevent complete discharge. What is needed for this? Periodically check the charge level. It takes no more than 5 minutes a day.
If the battery is already "dead", you can try to reanimate it. Use a starter charger with desulfation mode.
We save on the purchase of a new battery
Buy chargers with desulphation and save on buying a new battery. After all, now the battery will last much longer. Such designs are able to restore batteries to 95%. And most importantly, the cost of modern, functional ROM does not exceed the price of the battery.
So, it’s more rational to buy not a new battery, but a device with a desulfation mode.
Chargers with battery regeneration
Inverter chargers with desulfation are the most economical models. Such small structures are able to replenish the reserves of charges and reanimate devices.
Models need to be selected depending on the type and characteristics of the battery itself and the functions you need. you can buy a car charger with delivery in Ukraine to Kharkov, Kiev, Odessa at 130.com.ua.
Watch a video on the topic:
Materials on the topic
Starter-chargers: Best Sellers
