How to light a car from another car or battery
A dead battery during a trip is an unpleasant situation for every driver. Especially, if there is no charger at hand. One way to solve the problem is to properly light a car from another car. Most often such situations occur in the winter and it is important to do it correctly.
The battery can be discharged for various reasons, most often this happens in such cases:
- forgot to turn off the lights;
- left the car radio on;
- severe frost and already old battery;
- incorrect wiring.
The easiest way is to ask someone to light your car from some other. To do this correctly, you only need another machine and good wires.
The process is simple: your battery connects to another with wires and crocodile clips.
Wires for lighting a car
You need to use wires that can withstand heavy loads. Such mechanisms should meet the following criteria:
- Length in the range of 1.5-2.5 meters. Keep in mind that the longer, the higher the resistance. But working with very short is inconvenient.
- Section within 10 mm²-16 mm² Current strength from 200 A: here the higher the parameter, the better.
Visually, all wires should be soldered to the clamps. This type of construction provides the best conditions for good current conduction. It is better to choose wires with rubber sheath, since plastic can crack if it is very cold. The clips themselves should be wide open.
So, it is important to choose the right "donor": the car must be in good order, with full charge and no problems with electronics. Otherwise, you will then have to save both cars. And note that the voltage of the onboard network was the same.
Park in such a way that you feel comfortable installing the clamps on the battery terminals. Here the sequence is not important, you only need to take into account the polarity of the wires. On average, red is plus, black is minus.
Please note that sometimes there may be a spark when connected. Do not be scared. This is normal.
In some cars, access to the battery is limited, but there are special contacts. To do this, after connecting all the wires, we start the auto-donor and wait for 5 minutes. Then we start the auto-recipient and wait for 5 minutes too. Without drowning the motor, disconnect the wires.
After that, do not turn off the engine for 30 minutes, minimize the use of headlights, eliminate the work of acoustics.
Jump starters-a modern way to start a car
Jump starters are compact start-charging devices. Their main difference is the record compactness with high capacity. They are designed to start the car, if the battery sat down. They can also be used for electronics: devices are equipped with special adapters for this.
So, you will not need to ask others for help. Such a device takes up little space in the car, which means it will always be at hand. Now the problem of the dead battery is solved in a split second. you can buy a jump starter with delivery to Kiev, Odessa, Kharkov and throughout Ukraine for 130 .com.ua.
Materials on the topic
Starter-chargers: Best Sellers
