How to find the safest place in the car for a child?
Of course, that parents are thinking about where the car is the safest place for a baby carriage. Of course, there to protect the child seat, the current models are well protected against injury on impact, but also the installation of the chair seat, much depends. It is about what the safest place in the car for a child, and we'll talk.
What place in the cabin can be considered as safe as possible for the passengers, and why?
Everyone knows that in the event of a serious accident, the vehicle body is subjected to substantial deformation, which in turn can lead to injuries to the driver and his passengers. In order to minimize the potential threat to life, automakers are still in the development phase shall make every effort to create a passenger around a kind of "safety cell". This is intended to reduce the potential impact of the force of impact and reduce the destructive deformation of the body.
That is, with this in mind, can be considered the safest place where the risk of injury due to overloading and deformation will be minimal. It is a certain point inside the car, while in which the chances of survival for the passenger to be the maximum.
Many parents believe that it is enough to put the child back, so it will be safer, because it is in the back row of the risk of injury are minimal. But this is not quite true. Naturally the frontal impact of such a statement may be true, but it is not the only scenario. No one excludes the side impact or overturning the machine. And here it is to say that the back is safer not worth it.
The debate about where the child is safer going for a long time. And even the experts still not have a clear answer. Some argue that it is the rear seat behind the driver, because the driver if danger suddenly appears before him automatically responds, trying to divert the blow from themselves, thereby protecting the passenger and rear. Others are of the opinion that in the passenger seat. But in both cases, the passengers will be subjected to a fairly high risk of injury due to deformation of the door.
What about the safety of the statistics and experts?
To understand the place in the car, really is the safest, it is worth considering the statistics of real accidents. This is the real practical data, and not someone else's guesses and assumptions.
After you create a global system of independent crash tests, many researchers who are actively involved in the design of security systems, able to accumulate evidence to establish exactly where is still safer to transport the minors in the car. Together with data about the actual accident, US experts have managed to get quite interesting results.
It was found that a minimal risk of injury in an accident puts a child who is in the rear middle seat. Here, the degree of protection of at least 15-20% higher when compared with all the other places in the vehicle interior.
This is not surprising, as directly related to the technical features. Located on the central place in the back row, the child is not exposed to a potential risk due to deformation of the body, regardless of the type of impact: a frontal or side. After all, in any impact load primarily on themselves to take sides, hood, doors and roof (in the case of the coup). And in the center of the rear seat passengers will be at the maximum distance from potentially dangerous areas, then persists for more than important for the life of the space.
However, in spite of the data obtained in the course of the study, which suggests that it is the middle seat in the back row of the safest for the baby in the chair, as well as for any other passenger. Not all machines have the possibility of placing it there. After all, in practice, many modern cars is the most uncomfortable place. Except, perhaps, may serve as a minivan, where the rear row can accommodate immediately 3 separate seats. In many modern cars, for example, in the saloons of the elite or business class, is "central" place not at all, there is rest, a mini-bar or other items increased comfort.
Still, many of the cars are now equipped with special fasteners manufacturers with brackets type Isofix, allows you to install the car seat in the center rear seat. In addition, some machines also have a special seat belt (webbing transverse), which can be used to lock the passenger in the middle. If your machine has such features, it is in the center of the installation of a child seat will be most optimal from the point of view of safety of small passengers.
Do fasten the child should be?
Of course, that all allegations of security are justified only when certain conditions are met. Namely-the child must be transported in a special child seat, and at the same time it must be securely fastened with straps. This is very important because the chair provides extra hold, will not give the baby to fall and get hurt, and ensures additional protection against impact.
Unfortunately, in practice the situation often occurs when parents ignore these elementary rules. Someone says that the son or daughter sit fasten your seat belts "inconvenient", the child is naughty, crying, etc. But even if there is a chair and stands on the right place, and the child it is not fixed, as it should, on the contrary it significantly increases the risks.
In this situation, you can get very serious, incompatible with life trauma. And we must not get in an accident, you just really slow down dramatically, and the baby will fall out of the chair, risking injury. He owns a small child can not resist, so belts-is a mandatory attribute, and they are in the chair is not for beauty. Even if the kid is naughty, it is necessary to wear a seat. Try to advance to accustom the child to travel in a chair with straps, show by example that you also wear a seat and the car is not other way to go.
Recommendations on how to carry a child in the car
On the basis of information received, it is possible to draw some conclusions. In particular, there are specific guidelines for responsible parents who care about their children's safety during transport in the car. To the road the child was well protected, be sure to adhere to these rules:
- to install a special holding device for a child (seat) in the safest area of the showroom, which is a central place in the back row of seats, if possible, and by design of a particular vehicle;
- sure each time before boarding the baby in the seat to check the reliability of its installation and fixing;
- always, without exception, to fasten the child car seat fitted to belts or fix it by regular automobile seat belts;
- to disable the airbag, which are located near the installation of the car seat, especially important when transporting a child on the front passenger seat, facing backwards.
In addition, the driver must always remember that he had in the car baby, so you can not avoid aggressive driving. Since any accident, it is always a risk to all passengers. It is very important to strictly observe the speed limit, accelerate and brake smoothly as possible, without sudden movements and jerks.
Obviously, there is nothing unusual or difficult to fulfill in these requirements is not. However, compliance with these basic rules will help avoid possible problems and make driving with a child in the car as much as possible comfortable and safe.
In the online store 130.com.ua parents can always buy a baby car seat in Kiev, Kharkov and Odessa at a good price with delivery to Ukraine. We have a large selection of certified models from well-known and reputable world producers.
Related materials
Baby car seats and boosters: Best Sellers
