Impulse chargers: main differences and advantages
Imagine how much time you will have to spend if in the morning you suddenly find that your battery is dead. To avoid such a problem, you should always have a charger at hand. It can be of two types: transformer and impulse.
The first models have a high weight with a relatively low efficiency. Therefore, they have lost their relevance, because impulse models are becoming more popular. They are a light and practical device that guarantees a full charge of the battery.
Advantages of pulse storage
The main advantage of such models is their compactness: they are easily placed even in the glove box. This is especially convenient for drivers who often go on long trips. But impulse devices can boast other advantages:
- Automated work. You only need to connect the unit and at the end of the work - turn it off. The rest of the system will do it on its own.
- Improved protection system. As a rule, charging is equipped with various options for stabilization and voltage regulation, which eliminates possible breakdowns.
- Long battery life, because the charging process is completely controlled, which means that battery overheating is prevented.
The only drawback is that the repair of such structures is very expensive. Some car owners even prefer to buy a new device, but it all depends on the nature of the malfunction.
How to properly charge the battery?
Charging with a pulse memory has its own characteristics, so we recommend that you follow important recommendations:
- Remove battery for charging. Even if it is guaranteed stable and safe operation while using the battery, it is still better to be reinsured once again.
- Follow these instructions when connecting terminals.
- Even if you have an automatic device, it is better to check the system periodically. After all, a breakdown can happen at any time.
Such advice will protect you from any malfunctions and will significantly extend battery life.
Please note that the charging process can last up to 20 hours. And it is not recommended to chase speed, because in this case the battery will wear out much faster. In general, impulse chargers are not inferior to transformer ones in terms of functionality, but they offer more comfortable operation.
Buy a battery charger can be delivered to Kiev, Odessa, Kharkov and all over Ukraine at 130.com.ua.
See video reviews of battery chargers
Related materials:
Starter-chargers: Best Sellers
